What are these and can I cut them out?
Old Jan 17, 2015 | 05:05 PM
propaintball96's Avatar
Does anyone know what all these relays and modules are? I think the one all the way to the right is the MAP sensor... I want them gone they are ugly as ****.
Thanks!
Old Jan 17, 2015 | 06:34 PM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Re: What are these and can I cut them out?
One of them is the fuel pump relay
Old Jan 17, 2015 | 06:36 PM
Can't be because this car originally came with a mechanic fuel pump.
Old Jan 17, 2015 | 10:59 PM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Well I guess there's differences by years or options, but this is what mine is like
Old Jan 18, 2015 | 01:00 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
What year is the car, is it TBI,TPI ?
I would like to look at a few schematics but need more info.
Old Jan 18, 2015 | 09:22 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I'm going to guess 86-87 LG4 with the fan relay and fuel pump relay.
I'm also going to recommend learning what your car has and doesn't have, what things are and do and how things work before considering hacking them.
Old Jan 22, 2015 | 10:39 PM
Its a 1985 IROC and came with a Carbureted 305. No Electronic Fuel Pump. No Injectors.
Old Jan 22, 2015 | 10:41 PM
Could possibly be a Fan relay as it did come with an electric fan. But that is totally redone and has a completely different relay now.
And for the second part of your post...thats why I made this thread
Old Jan 23, 2015 | 09:19 AM
naf's Avatar
naf
Some 85s will have an in tank pump installed along with the block mounted mechanical. Look for the 2 wire pressure switch behind the dist tee'd off the 1 wire pressure sender for the guage. You can also jump the wires at the connector to see what comes on.
Old Jan 23, 2015 | 11:48 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
The 2 relays look just like my 1984 l69.
One is for the electric fan and the other is for the throttle kicker.
Old Jan 23, 2015 | 12:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Does it really matter what they're for? If they weren't needed GM wouldn't have spent the money putting them there. If you don't like how they look move them where you can't see them or make an attractive cover. Or don't open the hood!
armybyrd
Dec 5, 2015 09:22 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
