Cruise control
Old May 31, 2015 | 09:11 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Cruise control
Hi,
I am no mechanic by any means but I have 86 camaro in which the cruise control is not working. Any recommendation in how to toubleshoot to have an idea where the problem is? Any advice appreciated.
Old Jun 6, 2015 | 03:00 PM
podiatra's Avatar
Engine: 350 swap
Re: Cruise control
Any suggestion?
Old Jun 6, 2015 | 04:33 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Re: Cruise control
Usually the turn signal lever...real skinny wires get pinched and stop working
Old Jun 6, 2015 | 05:19 PM
podiatra's Avatar
Engine: 350 swap
Re: Cruise control
The wire is somewhere b/w the lever and the steering column?
Old Jun 6, 2015 | 05:23 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Re: Cruise control
Look on your turn signal lever you will see wires coming out from it facing the gauges usually one of those 4 wires is broke even though it might not be ripped it is not working at all
Old Jun 6, 2015 | 05:43 PM
podiatra's Avatar
Engine: 350 swap
Re: Cruise control
Thanks, I will do tomorrow and get back to you
Old Jun 6, 2015 | 07:26 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Cruise control
could also be vacuum related or a bad cruise control servo
Old Jun 6, 2015 | 08:48 PM
podiatra's Avatar
Engine: 350 swap
Re: Cruise control
Ant idea in how to troubleshoot b/w both?
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
