No Starter After Replacing Postive Battery Cable
Old Mar 11, 2016 | 05:13 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
1991 Formula 5.0 TPI 5-spd
The car started fine until I removed the positive battery cable.
There are 3 orange wires, 2 of which use the same connector and 1 which is solo.
The positive battery cable ends have 2 tabs that point down. One is straight the other has a odd curve. I assume this has to go on a certain way for a good connection? I have the tabs facing the starter but I think it's supposed to seat different.
It's a stock cable so I have one wire going to the back of the initiator and plugged in the wire connector.
I took it off a few months ago and tried to install again today but I think I"m doing something wrong. All the lights work etc. just no starter. I attached a picture to help.
Attached Thumbnails No Starter After Replacing Postive Battery Cable-img_0113.jpg
Old Mar 11, 2016 | 05:34 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: No Starter After Replacing Postive Battery Cable
Where is the purple wire connected to?
Old Mar 11, 2016 | 05:46 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
The S terminal(think that's the name) I never removed the purple wire though.
Old Mar 11, 2016 | 06:00 PM
antares57's Avatar
And you have all three fusible links along with the positive at the "B" terminal?
Old Mar 11, 2016 | 06:14 PM
antares57's Avatar
If so, here's a typical wiring diagram for your setup. If you're getting power through everything else, check your purple wire continuity through your clutch start switch.
Attached Thumbnails No Starter After Replacing Postive Battery Cable-starter.jpg
Old Mar 11, 2016 | 06:23 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
There are 3 wires(red) that connect with 2 different ring connectors. I assume those are the 3 fusible links?
What's the best way to tell if I have power at the starter? Can I just test with the car in run?
Old Mar 11, 2016 | 06:47 PM
antares57's Avatar
If you look at fusible link A it goes to power distribution. If you gave power in the car, you should have power at the starter. You can check with a voltmeter by checking between terminal "b" and a ground you should have 12 volts.
Old Mar 11, 2016 | 08:08 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Thanks Antares for the help so far. Tomorrow I'll check voltage and see about looking up how to check the neutral safety switch.
clubber
Mar 1, 2016 12:05 AM
gladback007
Feb 28, 2016 04:05 PM
kaydoe
Convertibles
Feb 27, 2016 09:41 PM
Instinctz
Feb 27, 2016 12:22 PM
redwolf7374
Feb 22, 2016 07:42 PM
