Front Turn signals don't work with headlights
Old Apr 14, 2018 | 10:18 PM
ERSMAGERD's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305
Hello, i have a 90 rs and recently the front turn signals went out. they don't seem to blink when the headlights are turned on. if i move the headlight switch in any position besides off they will not blink but will still light up. i'm sure it isn't the bulbs but have no idea what else it could be.
Old Apr 15, 2018 | 08:48 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Front Turn signals don't work with headlights
The ground wire for the light harness , screwed into the radiator support , has become disconnected , rusted off , or is otherwise not making a good connection . When your headlights are off , the turn signals are finding their ground "backfeed" style through the headlights themselves . When the headlights are on , no possibility of the turnsignals finding that ground path = no blinking .
Find & fix that bad ground & all will be right again with your lights ....
Old Apr 15, 2018 | 11:15 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
let there be light !!
Old Apr 15, 2018 | 11:16 AM
ERSMAGERD's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305
where exactly does the harness ground with the radiator mount? I can't seem to find any place where it would be?
Old Apr 15, 2018 | 11:49 AM
OrangeBird's Avatar
Car: 1989 Firebird
It's on the metal the radiator is mounted to , on my Firebird it's on the driver's side in front of the battery . But I'm not talking about the one that is supposed to run from the battery's - terminal to the top of the radiator mount , this is one that comes out of the headlight harness and gets attached to the area just in front of the battery and on my car I'm pretty sure you can't see it with the battery in place .
Old Apr 18, 2018 | 10:38 AM
ERSMAGERD's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305
so all of my grounds seem to be in good shape. I noticed that the blinking element of the bulb is working but the solid element still stays on. Don't know if that means anything, but figured I'd include it. All the wires and the sockets all seem to be in good shape as well.
Old Apr 21, 2018 | 11:12 AM
OrangeBird's Avatar
Car: 1989 Firebird
Just noticed your post , Are you at all handy with a voltmeter ? If so , the thing to do here would be to see if the side of the bulb socket that's supposed to be ground IS actually grounded , because your problem does sound like the classic symptom of a lost ground .
Old Apr 23, 2018 | 11:43 AM
ERSMAGERD's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305
yeah im pretty familiar with a voltmeter, i can check that.
Old Apr 23, 2018 | 03:41 PM
ERSMAGERD's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305
went through with a voltmeter and the sockets ground but was wondering if this was the ground for the turn signals or not. It's near the drivers side firewall and comes off that harness.
that1guy24
Oct 30, 2016 09:32 PM
JoshuAA1990
Jan 25, 2011 03:46 PM
BigWhiteGTP
Feb 16, 2005 09:13 AM
87project2.8
Apr 9, 2004 06:03 PM
