Big hacking job in the convenience center?
Old Nov 14, 2018 | 09:36 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi guys, what the hell is this mess? The previous owner decided to move everything into the convenience center, to do what? Why is a Mercedes dude line installed, and the ALDL socket was moved near the fuse box? I need a big help to restore the original conditions! Reasons for this?
Old Nov 14, 2018 | 10:24 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Big hacking job in the convenience center?
What in tarnation?!? No idea what they did with that. You would have to start tracing wires
Old Nov 14, 2018 | 10:31 AM
Engine: 3.1 LH0
*dude: fuse
okay, I’ ll try. I don’t know what I’m going to find there...
Old Nov 14, 2018 | 10:52 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Can't really help unless we know what you are looking at, which means you either have to get another, virgin, harness or you have to tell us where the wires go.
Are there auxiliary lights installed, alarms, etc?
Old Nov 14, 2018 | 10:58 AM
Engine: 3.1 LH0
Yes, I understand.. I think there was an anti-theft system before I bought the car, the fuel pump relay wires where spliced and badly soldered... I’ll keep you updated as I will take it down this thing... where can I get a new original harness?
Old Nov 14, 2018 | 11:03 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You will have to find someone parting a car of the same year and style as you have to change the harness
Old Nov 14, 2018 | 06:38 PM
Drew's Avatar
ALDL location is normal for later cars. The only thing wrong with the convenience center is that someone removed the chime module. You could probably plug one right back into it, if you want the door/light/belts buzzers.
The added fuse block is probably part of a security system install, or maybe stereo or other electronics. Chase where the wires go, it should become obvious what they are for.
Old Nov 15, 2018 | 02:50 AM
Engine: 3.1 LH0
Can it be somehow related to engine stalling problems, like loose connections or gounds in this zone?
Old Nov 15, 2018 | 08:17 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
As I said before, we can't help you without knowing what those go to. It is, though, unlikely that it is grounds. There are only a few in the interior, one for the dash and one under the center console. I can't think of the others right now
blue_tacos
Apr 13, 2012 09:22 AM
Randy82WS7
Mar 18, 2007 12:24 AM
ptc92rs
Sep 11, 2004 12:34 AM
gtaproject
May 18, 2003 03:41 PM
92-Formula
Oct 11, 2001 05:37 AM
