91 Camaro won’t start
Subscribe
Mar 1, 2019 | 01:49 PM
Anybody can explain step by step how to completely remove VATS I think that may be what’s causing my car not to start and I noticed it has a aftermarket alarm I want to remove that as well
i have no need for a Alarm on my vehicle PERIOD
Reply 0
Mar 1, 2019 | 04:51 PM
Re: 91 Camaro won’t start
How to remove VATS Completely, Idk and I speculate it's much harder a tasks than it seems. Also, I thought the "Starting Issue" was addressed in https://www.thirdgen.org/forums/elec...ump-start.html where it was stated on 02/27/2019 "I got the car started yesterday it was my battery needed to be charged up at Autozone it’s 4 years old" If VATS was truly the reason there would be an amber colored security light on in the Gauge Cluster and it wouldn't go off. If you do not have a consistent Security Light VATS isn't your issue. Btw, Unless you are an Automotive Electrician or have the Wiring Schematics I do not suggest tampering with trying to remove an aftermarket alarm either.
Reply 0
Mar 1, 2019 | 05:04 PM
Turns out the Battery is Toast even after I had it charged up at autozone it still died on me...I didn’t see a security light on in the dash when I turn the key it does not crank or do anything
Reply 0
Mar 1, 2019 | 05:07 PM
I just want any Useless electronics removed from the car I never trusted aftermarket alarms ...I’m not doing the work myself I want a shop to remove any pieces of alarm system in the car
Reply 0
Mar 1, 2019 | 05:18 PM
I've learned many costly lessons by jumping into DIY w/out the correct knowledge, so yes that's the best bet....
When you have a Known Good or Known Charged battery pay attention when your turning the key to the 1st position (Run Position) you should have LEDs for BRAKE, INFL RESET, and SECURITY light up I know for sure... INFL will remain lit if there's an Airbag issue, BRAKE will remain lit if the E-Brake is engaged and SECURITY should come on for about 2-3 seconds and go off if the VATS system is operational. If it truly "does not crank or do anything" then my friend revisit that battery situation first.
Reply 0
Mar 1, 2019 | 05:59 PM
I’m picking up a Brand New Battery today and I’m gonna install it and hopefully start the car and see what happens
Reply 0
Mar 1, 2019 | 07:27 PM
Brand new battery installed still nothing happens no crank no start no click absolutely nothing happens so I don’t know what to do at this point
Reply 0
Mar 1, 2019 | 07:29 PM
Have you tried to jumper the starter enable relay?
or atleast check for power when you turn the key to crank position.
Reply 0
Mar 1, 2019 | 07:31 PM
Reply 0
Mar 1, 2019 | 07:39 PM
When I turn the key to the on position I just see a brake light a INFL light and the temperature gauge needle goes all the way to the end ...I got Headlights dashlights everything works...just no crank no start
Reply 0
Mar 1, 2019 | 07:40 PM
I haven’t tried any other methods my electrical skills are not great
Reply 0
Mar 1, 2019 | 07:50 PM
A volt ohm meter or test light are very cheap. You can make a jumper to bypass the relay the two larger gauge wires get jumpered together. Of while trying to crank the car over check for power at the yellow or green wire. If you have power there vats is the issue and needs to be fixed or bypassed in one of the ways mentioned in the link I posted.
Reply 0
Subscribe
