Dumb question, where does this wire go?
Old Apr 25, 2020 | 12:36 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
It comes off the red battery cable
Old Apr 25, 2020 | 01:25 PM
Re: Dumb question, where does this wire go?
ECM
Other half of it should be somewhere nearby
Might have something to do with your Check Engine light
Old Apr 25, 2020 | 01:55 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
ECM
I guess we messed up bad, we thought the other end of that wire went to the 02 sensor so we put in an extension to the wiring harness because since I have headers now we thought that was causing it to not be long enough. So where can I find the other end of the 02 sensor wire? It seems to be missing
Old Apr 25, 2020 | 02:45 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
EDIT I think I figured it out guys thanks for the help
Old Apr 25, 2020 | 03:45 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
What did it end up being ? In case some one has the same problem and finds this thread.
Old Apr 25, 2020 | 03:55 PM
If you somehow managed to plug the O2 sensor into that wire, you probably smoked it.
Better get yourself a new sensor in that case.
Old Apr 26, 2020 | 12:18 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
no I did it right it’s ok
Old Apr 26, 2020 | 12:19 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
the ECM wire was hidden I located it and plugged it in
Ghettobird52
Sep 12, 2017 07:44 PM
dwright69
Jul 17, 2008 04:23 PM
Hoosier Bob
May 20, 2008 08:20 PM
xlwhellraiser
Car Audio
Jun 2, 2006 05:28 PM
Berlinetta
Apr 15, 2004 12:43 PM
