Can you change magnetic pickup on an MSD 8366?
Car: 87 IROC
Engine: 383
Transmission: 700R4 MODIFIED
Axle/Gears: 3:83
I removed the two hex screws holding it in place but I believe it might be epoxied to the distributor.
Does the factory habe to do a rebuild or can I get this off myself? NEED ADVICE.
Re: Can you change magnetic pickup on an MSD 8366?
Car: 87 IROC
Engine: 383
Axle/Gears: 3:83
Thanks I have that part. Problem is removing the old one. It appears to be epoxied in place. I removed the 2 screws but it will not budge. I am afraid if I put too much pressure on it I will bend the aluminum plate it is epoxied too.
Car: 87 IROC
Engine: 383
Axle/Gears: 3:83
Which wire from the magnetic pickup goes to what position on th ignition control module. (Wire color to letter would help alot)
Car: 87 IROC
Engine: 383
Axle/Gears: 3:83
Thank you.
The magnetic pickup needs to wire to the ignition control module. I need to know what color wire goes to each letter on the ignition control module.
Control module has. "P" or " N" marked on it.
See picture.
See picture.
https://www.holley.com/products/igni...ts/parts/84665
You should be able to figure it out from the above link.
Brandog87GTA
Nov 17, 2000 11:59 AM
