Hatch motor issues questions ?
Old Jan 11, 2021 | 02:32 PM
88irocz91rally's Avatar
Car: 1988iroc z and 1991 Camaro Rs
Transmission: 4 speed and 5 speex
Ok I have a 1988 Camaro iroc-z this is my second time rebuilding my hatch motor first time the cheap china hatch motor housing broke in a year I bought 2 motors 2nd one as a spare also China unit.
So this is the issues first when I hook everything up it doesn't move but the motor is getting hot and when I push the engagement switch on top I hear it try to do something but it won't move funny thing is when I tested out of the car I poked the motor with 12 volts and a ground and it worked moved up words ok to go to the top , but won't go in reverse or pull hatch down in the car. I checked the lid fuse was ok and the acc 20 amp fuse looked ok.
Last question is there is a little white wire that I see nothing it plugs into in picture not sure what it is for?
Old Jan 11, 2021 | 05:51 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: Hatch motor issues questions ?
Mine’s not hooked up to anything either.
Old Jan 14, 2021 | 10:16 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
When you put it together, did you make sure the trigger was in the right spot to engage the reverse switch? Or maybe your reverse switch crapped out
Old Jan 17, 2021 | 08:42 PM
Good point , I'll flip the switch see what that does and or try a different reverse switch I have. Do you know off hand what position the switch is spose to go if your looking down on the hatch motor in the car?
Old Jan 17, 2021 | 09:59 PM
dagwood's Avatar
Top Answer: 1
I'd have to look at one again. I do remember putting one together wrong, though. It seems like it's actually HARD to assemble it in the right spot. My spare ones are at my brother's farm an hour away, so I'm not going to have a fast answer for ya.
Old Jan 18, 2021 | 07:08 AM
Alright cool, I might get it figured out by then but then again I might work on some other stuff, thanks allot!
Old Jan 27, 2021 | 03:59 PM
Update figured out what was wrong . The switch that plugs into motor when you connect or push it into the motor you must make sure the switch is in the middle of the two cogs that way when motor lowers it pushes switch down and when rasies it pushes switch up . When I assembled it I failed to see that.
The reinforced housing that I bought from top down solutions is awesome I highly recommend them!
Old Jan 28, 2021 | 01:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IIRC the later cars taillight harness ( 90-92 maybe ? ) connected to this wire; switched ground for interior courtesy lighting.
Old Jan 30, 2021 | 12:37 PM
Mark RWC's Avatar
My 88 firebird uses the white wire off the relay to turn on the light in the hatch panel when the lift motor has the hatch in the lifted position.. The light also has a slide switch to turn on the same light manually.
dps8315
Jul 7, 2024 08:46 PM
IMissMy86TA
Sep 26, 2011 07:47 AM
GodSpeedGTA
Jan 16, 2006 05:37 PM
ChevyCamaro420
Mar 11, 2004 07:24 PM
NHFrebird
May 4, 2003 09:25 PM
