Adding a knock sensor to carbureted engine to retard timing control detonation
Re: Adding a knock sensor to carbureted engine to retard timing control detonation
Want protection against knock, ping and detonation? This is the cheapest, easiest way to do it. Get a GM ESC controller and a knock sensor (with 100k olms resistance). Wire it as shown in the wiring diagram. This system does NOT control timing.... the vacuum and mechanical advances in the distributor do this. The ESC controller only adjusts timing if knock is detected. This system can be used on ANY engine that has a distributor and a magnetic pickup coil. It can be used on any four, six or eight cylinder engine. The module and/or coil can be externally located if need be. I would highly recommend adding a knock sensor to any engine that is high compression, supercharged or turbocharged.
Car: 87 iroc-z
Engine: 454
Transmission: th350
Cool idea. Reminds me of the cheap boost retard with the 5-pin.
https://www.instructables.com/Dirt-c...harged-engine/
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Question on knock sensors. Trouble shooting guide for code 43 (I believe) knock, says sensor should read about 3900 ohms? You mentioned 100k ohms and I have 4 knock sensors that all read in that range, 90 - 100k. So I assume the T/S guide is wrong. Are there knock sensors that are different or more desirable than others? Different in their ohm value I suppose. Different maybe for the size of the engine? 305 v 350?
Thanks! Now I have to retrieve my T/S manuals from the dumpster.
Not anything new...
But an Excellent Write-Up and Thread!
Nice Job!!!
Nice Job!!!
Looking for a part Number for 3.9K ohm Knock Sensor. I have a 1989 Firebird Formula 350. I have ordered 3 already and all of them measured 100K Ohm. I test installed a 3.9K ohm resister in place of the Knock sensor and it worked perfect, no Check Engine light. Will not having the knock sensor plugged in make timing retard? Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
85-89 uses a 100k ohm knock sensor
90-92 tpi was 3.9k
90-92 tpi was 3.9k
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
if only this could be integrated into a Holley Sniper EFI using the Hyperspark!!!
