Low/High beam issues
Old Oct 13, 2022 | 08:08 AM
matthew911's Avatar
Car: 84 Z
I searched the forum first looking for answers, but I didn't see anyone with this exact issue. When I pull the lever part way, the parking lights turn on. When I pull it all the way, the outer headlights turn on, but the inner ones don't work at all. Should the outer lights work on the first pull, then all four work on the full pull? I saw a few posts talking about the switch on the column needing adjusting occasionally, but when I looked underneath I couldn't see anything moving when I pulled the lever.
Old Oct 13, 2022 | 10:11 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Low/High beam issues
The headlight pull switch only operates the low beams and the parking lights, just as you described.
To turn on the "brights" and activate all 4 front lights you have to pull back on the turn signal stalk.
Old Oct 13, 2022 | 11:57 AM
matthew911's Avatar
Car: 84 Z
Ah, ok. That was one of the first things I tried, but it looks like the stalk is broken then. It pulls forward but there's no click or anything. Any idea what needs to be done to get that fixed? I'd prefer not to take the entire steering column apart...
Old Oct 13, 2022 | 12:18 PM
Car: 1983 Z28
Yeah, if you're not feeling/hearing the "click" then the switch is probably broken. Here are a couple threads with info on disassembly. It's, well, tedious, but not impossible.
https://www.thirdgen.org/forums/elec...al-switch.html
https://www.thirdgen.org/forums/inte...eel-grant.html
Old Oct 13, 2022 | 12:21 PM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
This the dimmer switch which is located on the side of the column and can be changed without taking the column apart. This is what makes the clicking sound, there is a rod that comes off the turn signal switch that operates the dimmer switch. The pic below shows the dimmer switch, it can be adjusted. I'd check it for improper adjustment if you just got the car. If the stalk is broken, then you have to disassemble the steering column.
1982-2002 Camaro/Firebird Dimmer Switch (screamingchicken.com)
Old Oct 13, 2022 | 08:19 PM
matthew911's Avatar
Car: 84 Z
On the steering column. Not sure how it's supposed to attach to the lever?
And here's underneath.
Old Oct 14, 2022 | 06:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I've had issues with the knee bolster interfering with the hi/lo activator rod. This is the panel that is directly under the column. Same as you couldn't get a click from the switch. Loosen the bolster screws and try the hi/lo again. If it now works the bolster is hitting the rod.
Just need to slightly bend the bolster so that the center section is further down. Did this by bending the outer areas up and replaced it. Good to go. Note that the bolster is thin sheet metal covered with a padded vinyl.
RBob.
Old Oct 14, 2022 | 07:04 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Check to see if the rod is in the proper location on the switch as shown in #5.
Old Oct 14, 2022 | 08:54 AM
matthew911's Avatar
Car: 84 Z
I can place the rod back inside the switch, but I can't see where it's supposed to attach near the lever. If I move the rod manually, it doesn't seem to move the switch far enough to activate it either.
Old Oct 14, 2022 | 09:09 AM
scfbody's Avatar
There is a cam on the lever that causes the rod to push on the switch, it doesn't attach. You have to adjust the dimmer switch so that the rod will move it enough to activate it. It is held in place by two small screws, loosen the screws and you can move the dimmer switch closer or further away from the lever/rod. I'd get the rod placed in the dimmer switch and that should make things easier to adjust.
Old Oct 14, 2022 | 06:18 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Your first post suggested to me that this part has probably fallen into the column or is missing completely. That's the "cam" that scfbody mentioned, and it's similar in size to the one in the picture.
Its located inside of the column cover and fits between the base of the signal lever and the rod, held into place only by the pressure between them. If the rod has become dislodged from the switch, then that little plastic piece has most likely fallen into the column or is missing.
Dumbest design ever; you'll see when you find it/one and try to install it. To install it, you'll have to disassemble the column to the point of being able to slide-off the column cover from around the turn signal lever area. The last time I installed one, I used a dab of lithium grease to "stick" it to the column while I reinstalled the cover.
Old Oct 14, 2022 | 07:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Fits between the rod and signal lever and on the plastic cover. Also the rod at the other end is out of place. As seen on post #5.
CamaroNZ
Sep 27, 2020 10:02 AM
oSnooZe
May 24, 2013 11:10 PM
Valtyr
Jan 2, 2013 11:28 PM
morrison311
Jul 25, 2011 07:19 PM
camarors8992
Aug 12, 2005 09:06 PM
