Alternator clearance
Old Feb 19, 2026 | 05:02 PM
dgordond's Avatar
Car: 1989 IROC Z black, stick ,hardtop
Engine: 383 AFR heads FIRST intake
Transmission: ProMotion T5
Axle/Gears: 3.42 TorsenTen Factory axles
Has anyone run into an issue with alternator to valve cover clearance? 1989 5.0 tpi, the boss sticking out of the rear solid hits my tall aluminum valve cover , can't install it. mine has the lug sticking out that accepts a bolt thru wire. can't even reclock it because i can't get it apart to get case attaching bolt riser past lower mounting bolt boss. hopin someone has seen this and has a cure. i believe i need a solid half in less sticking out. Thanks!
Old Feb 19, 2026 | 05:21 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Alternator clearance
Mark the spot and massage the valve cover enough to give adequate space for the lug.
Hit up a shop that does aluminum and have them notch the area and re-weld it
Old Feb 19, 2026 | 09:13 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
or take the bolts out of the back of the alternator and turn the case, AKA clock it, so it fits correctly without all that nonsense you wrote..
Old Feb 20, 2026 | 08:20 AM
Or put valve covers on it THAT FIT.
The problem isn't the alt, it's the VCs.
Old Feb 20, 2026 | 09:23 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Might gain enough clearance if you take the alternator apart and swap that lug type output terminal to the stud and nut style, trim down the stud and use a thin nut.
Old May 13, 2026 | 06:38 AM
Gunmetal89GTA's Avatar
I have the same problem as the OP. I was looking at the factory alum brackets from the 5.7 trucks same years. They look to set the alternator up higher; has anybody tried one of those? Does the offset from face of block put the ALT & PS pulleys in-line or we talking new water pump, AC bracket, etc? I would think the harmonic is boss.
I've been mocking up a spare alternator by clocking it and grinding the backside, but I hate the aesthetic of the tight tolerance. And because of the clocking, the rear brace can't get installed. Right now, I'm working on some offset brackets to move the alternator up about 3/4-1" from the stock height to at least get the batt stud up higher. Thoughts welcome.
Old May 13, 2026 | 07:53 AM
BURD's Avatar
When you “jegg” it up, you gotta but all the AM crap to make it all work.
Old May 13, 2026 | 08:26 AM
"AM" crap? Maybe a stupid question
Old May 13, 2026 | 11:49 AM
dgordond's Avatar
I did finally get up the nerves to pull apart my unit enough to reclock it. built a ton of alternators before but apparently not one of these , was a bit shaky getting it apart but it seems ok. I dont haqve nearly the issue you have with covers , i am good at this point just with reclock. Thanks!
I ended up just reclocking mine and being ok,not nearly as close as your fit. have built a lot of alternators but not this style where you have to be a bit rough to separate enough to turn but its all good.Thanks. sorry my pics appear huge before submitting, not sure how to fix that
Old May 13, 2026 | 03:05 PM
kmac1036's Avatar
Car: 1991 Z28 Convertible
Transmission: "World Class" T5
Axle/Gears: 3.08
which alternator is this? what's the amps output? asking for a friend that wants to put a big amp in his
Old May 14, 2026 | 08:58 AM
BURD's Avatar
AM = AFTERMARKET.
How much HP did jeggs tell you you scoupe up with AM vavecovers.
HP= Horsepower to be clear.
Old May 23, 2026 | 05:05 AM
AM = AFTERMARKET.
Thanks for the clarification. The VCs are for clearing the roller rockers below. We're currently working on notching the VC to clear the alternator. To your point, I hope I don't lose any HP doing so
85Iroc-Z
Apr 23, 2014 02:17 PM
91interceptorZ
Jan 11, 2010 09:30 PM
camaronewbie
May 4, 2006 07:58 PM
