[TN] 350 tpi Engine/SLP/LT4/fastburn heads
I have a 96 Chevy 350 with TRW pistons +30 stock crank GM PM Rods, LT4 Roller hot cam hit with roller rockers. Summit racing fluid dampener, GM fastburn heads, SDPC TPI Base for vortec heads, SLP runners ported stock Plenum ,Stock TB, Stock Fuel Rails with Adjustable regulator. Everything has been polish shed and balanced. The short block has been assembled but its been sitting for a while I would take it apart and reassemble it and make sure everything is good to go before use. The heads are used with around 1000 miles on them. I have about 7k in everything and would like to get $3500 OBO for it all. I don’t have pics now but will get some if anyone is interested. The runners and plenum and fuel rails have all been polished and look great. All parts for the engine are new never used or no miles since polish and machine work done. Cam roller rockers lifters all new still inbox with spring’s retainers for the heads.
Thanks Earl
Thanks Earl
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: 350 tpi Engine/SLP/LT4/fastburn heads
Well how much for the shortblock with cam and heads...aka longblock
The short block is asembld but the guy that did the work died in the middle of it so I would take it apart and at the least retorque every thing every thing else except the heads is new in the boxs they cam in it was balanced so the dampner has been removed and had some wait removed for that. The flex plate is new in the box dont think he removed or added wight. heads I used on a mtotr for a little while until i sold the short clock to some one wanting a strocker. Ill take 2800 OBO for the long block and all the parts with it.
Sanjay
Aug 12, 2015 03:41 PM
