TPI - LT1 IAC Mod
Old Feb 11, 2010 | 02:48 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
TPI - LT1 IAC Mod
I can modify your IAC to eliminate the coolant passage keeping your fuel cool.. and a few ponies
also makes a nice clean TB area and eliminate the ugly hose or plug blockoff
send yours in $25.00 + shipping
send a msg or PM
[IMG]file:///C:/DOCUME%7E1/STUART%7E1.NFR/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/DOCUME%7E1/STUART%7E1.NFR/LOCALS%7E1/Temp/moz-screenshot-2.png[/IMG]
Old Feb 12, 2010 | 08:10 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: TPI - LT1 IAC Mod
where are you in NY? i might be able to just drop mine off lol
Old Feb 13, 2010 | 12:07 AM
88gta3508's Avatar
Engine: 231 / 383
well when you get your TPI swap!!!! you should
Old Feb 13, 2010 | 09:35 AM
i have all the parts just havent swapped yet its too cold to work outside and i dont have a garage or access to one, but yeah where are u located?
Old Feb 13, 2010 | 11:13 AM
88gta3508's Avatar
Engine: 231 / 383
I'm 17 miles east of Albany, NY Actually.. I have one complete on a LT1 setup
I would need your housing minus your IAC to replace mine
Old Feb 13, 2010 | 12:04 PM
im not sure the LT1 will work with the tpi im pretty sure theres a post on here about the throttle linkage not being the same mine is from a 1988 tpi but i would be gald to do an exchange if you have one that will def work
Old Feb 13, 2010 | 12:19 PM
88gta3508's Avatar
Engine: 231 / 383
look @ the pic just The IAC housing that bolts under the TB for TPI and LT1!! are identical!!!
I have both cars
NOT the Throttle body.. yes they have A different Throttle pivot arm and a different TPS
Old Feb 13, 2010 | 02:31 PM
sorry for my ignorance
Old Feb 14, 2010 | 12:18 AM
88gta3508's Avatar
Engine: 231 / 383
no no don't say that it's just a honest mistake
Old Apr 6, 2018 | 12:51 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
What are you guys doing with the other end of the hose?
Just block it out with a plug ?
After the mod a light sand blasting or other media blasting might be in order
to blend it in.
Old Apr 6, 2018 | 12:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old post, here is a bypass hose number.
https://www.thirdgen.org/forums/tpi/...***-valve.html
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
