[Sold] Kenne Bell Boost-A-Pump 17.5V, 40A
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Kenne Bell Boost-a-Pump. 17.5v output, "Street Version" Single pump, it has 30 17 stamped into the bottom of it, which according to a Kenne Bell rep on another site makes it a 40A unit
Second pic of unit working only shows 17.36v because the car is off. Fire the car up and it goes right up to 17.5v.
Comes with a harness to plug in if you have the "hot wire" kit so you don't have to splice wires. The switch is the vacuum switch, open when vacuum is applied so the unit only comes on when you are at WOT. I have wiring/installation instructions for it.
I picked this up from a friend in excellent used condition. Intended on running it with the procharger on my 3rd gen, went in a different direction.
Goes for $280 new, asking $175 OBO + shipping.
here is a link to the website for more info.
http://www.kennebell.net/accessories...boostapump.htm
Thanks!
Will
Thanks!
Will
Re: Kenne Bell Boost-A-Pump
TTT
There isn't a part number on it that I can find. I believe it is a 20A, It is my understanding the larger one is the 40A.
Updated INFO on pump.
Re: Kenne Bell Boost-A-Pump 17.5V, 40A
SOLD
topteam54
Oct 6, 2015 12:21 AM
roysatikas
Sep 22, 2015 08:15 PM
Denricci22
Sep 18, 2015 09:02 AM
