[NJ] Summer & WINTER! cleaning, gaskets, filters, ignition, cooling fans etc!!
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Got a bunch of stuff that I just want to get rid of.
everything is brand new and unused esp the gaskets of course.
felpro 1205 with distributer gasket
Mr gasket ultra seal valve cover gaskets for center bolt valve covers
pairs of felpro TPI throttle body gaskets
K&N 14"x3" high flow carb filter NEW still i box and plastic
edelbrock proflow filter NEW
2 packs of transmission mounting kits (through rad)
2 blue covers for ECM memcals NEW
Gator Oil filter relocation hoses, premade 1/2" ID 1/2" NPT ends designed for universal oil filter relocation kits and spin on block adapter with Oring gasket
Brand new MSD blaster 2 coil in package with instructions/stickers etc
SOLD2 procomp 12" electric pusher/puller fans, unused.SOLD
10 gorrilla locking lug nuts GM with special key (the bags are summit for different lugs but they were a good size for these)
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Summer cleaning, gaskets, filters, ignition, cooling fans etc!!
high flow air filter?
Car: 87 TA clone
Car: 87 TA clone
which one? K&N or the pro flow
30$ plus the ride for K&N. Filter goes for 50$ from summit plus 11$ handling.
15$ shipped for the pro flow. filter goes for 17$ plus the handling.
Car: 87 TA clone
its not a full relocation kit, just the block adapter and the hoses. I mixed kits when I did mine. getting the block adapter and hoses is nice bc now you can get the type of remote mount that you want for you application. These are not the cheap hoses, these are pre made (flame resistant) good for 300psi and brass swivel ends. cheaper kits come with rubber hoses and nipple fittings and hose clamps.
asking 35$ plus the ride.
Car: 87 TA clone
Pic for NYciti
not the rad is moved to the pass side 3" and knotted the front subframe to shift it over. Rad is a 31x19 summit universal ford rad and I think the core size is 25"x17". Aluminum U chanel is 3/4" x 1/2" or 1"x1/2" from home depot. Fans just need a +12 V and a ground.
Car: 87 TA clone
FANS ARE SOLD!
Everything else still available.
Car: 87 TA clone
Car: 87 TA clone
BUMP! Come on guys!
I found 7 more the of locking gorilla lug nuts so theres now 17 total.
Car: 87 TA clone
BUMP!!!
Car: 87 TA clone
everything still for sale except the fans!
shoot me some prices and well talk, I want this stuff gone.
Car: 87 TA clone
Come on guys, want all this stuff gone! Make me some offers
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Interested in felpro gaskets and tpi gaskets and valve cover gaskets let me know what else you got thanks.cani get close up pictures email to martinez1607@gmail.com please and thank you.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
how much for the oil filter relocation stuff to 71047? thanks, Greg
Car: 87 TA clone
Car: 87 TA clone
I was asking for 35$ plus the ride. Hard to tell about shipping, if shipped USPS it shouldn't be that much. Issue is the Hoses as I don't want to bend them too hard so I would have to put in a larger box which would increase shipping costs. say that 42$ shipped is a fair estimate. I'll eat the costs if its over 7$ to ship.
Car: 87 TA clone
Adding some more stuff to the list of stuff i want gone guys. Take a look!
More gaskets, some other stuff as well. I have other threads with exterior and interior stuff for sale as well.
If you want to know what I got let me know.
Heres a quick list
exterior:
firebird front driver fender
firebird headlight module
base firebird shorty wing with 3rd brake light
camaro shorty spoiler long center part only!
Firebird rear decklid will fit camaro too
custom handmade fiberglass wrap around spoiler with integrated 3rd brake light
Full electric (windows and locks with glass) firebird/camaro passenger door
Firebird 90-92 headlight bezel plastic part
Spare 3rd brake light firebird
Wiper arm setup, everything to bolt up to the motor
Interior:
spare parts of 120mph firebird cluster, speedo, and all other gauges minus the tach, lense conver is in great shape
stock firebird gauge panel/cluster shroud for above style gauges
Stock V6 instrument cluster
stock V6 gauge panel/cluster shroud for V6 cluster above
Bunch of steering column parts (inner wiring and signal cams) plus wat seems to be a grant mounting bracket for steering wheel
Firebird Headlight switch
Heater/AC controls
Custom Subwoofer boxes for rear cargo area.
Engine/drivetrain:
TPI rear distributer cover
TPI gaskets see pics
Mr gasket ultra seal valve cover gaskets see pic
Stock steel core Felpro 305/350 1965-1995 intake manifold gaskets (see pic brown box) has heat/cross over pieces as well as rubber valley gaskets and distributer gasket
exhaust header gasket see pic
Felpro 1205 intake gaskets NEW package opened but never used
Header flanges and gaskets with kit (headman headers) see pic
mr gasket 160* high flow thermostat see pic
adjustable fan switch with temp radiator probe see pic
Gorrilla special locking lug nuts with key see pic (package is not correct they are gorilla just needed to put them in something)
Allstar Black Anodized aluminum hood pin kit new in package see pic
Trans dapt oil fill cap for push in style breather holes 1.25" see pic and NEW still in package
Proform chrome alternator spacer, brand new in package see pic
CSR Polished 16lb Radiator cap, new and out of package, used for mock up
Edelbrock Proflow high flow air filter setup for carb with 5 1/8" carb hat, brand new still in package see pic
Oil filter relocation block adapter with Oring, preassembled high dollar oil filter relocation lines with special high flow brass fittings for oil filter kit, see pic
K&N 14"x3" high flow filter see pic
1 reinforced Front Lower control arm see pic
Heres a quick list
exterior:
Interior:
Heater/AC controls
Engine/drivetrain:
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: Summer & WINTER! cleaning, gaskets, filters, ignition, cooling fans etc!!
How much for the Felpro 1205 and TPI gaskets shipped to 33428??
Car: 87 TA clone
which TPI gaskets? not sure about the runner gaskets as to top and bottom but it looks like I have at least 2 full sets of runner gaskets and 3 sets or more of the TB gaskets. I know the runner top gaskets one side has the slanted corner (pass side I think). Let me know what your interested in and ill try to figure out a price.
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
The gaskets for the throttle body. And give a price for the runner gaskets as well. And of course the 1205 too all shipped to 33428. Thanks.
Car: 1987 Iroc Z
I was asking for 35$ plus the ride. Hard to tell about shipping, if shipped USPS it shouldn't be that much. Issue is the Hoses as I don't want to bend them too hard so I would have to put in a larger box which would increase shipping costs. say that 42$ shipped is a fair estimate. I'll eat the costs if its over 7$ to ship.[/quote]
-- is that everything i would need to relocate the filter?
Car: 87 TA clone
No, you would need a remote filter base. The part you mount and the filter will now screw onto. what Im selling is the part that spins onto the block 3/4-16 thread i believe, then you have the lines connecting that block adapter to the "remote filter base"(which Im not selling). So thats all you would need. I bought a few kits as none of them had what I wanted completely. Hence why I have extra parts. Its good that I'm not selling the filter base bc now you can find one that you want and works better in your application.
Car: 87 TA clone
double post.
Car: 87 TA clone
You guys still interested?
Car: 1987 Iroc Z
i think i'm gonna pass on the oil relocation for now. i wanted to make some room for a new exhaust setup, but now i am having engine problems....
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
