AFR 195's with ARP bolts for sale
Car: 1991 Camaro Z28
***SOLD***
$750 plus shipping. One of the plug holes has a thread that is buggared up the on of my mechanic buddies said it is a easy fix with a thread chaser just don't have one. Selling to get money for ls swap. Also you will get the arp bolt set with the heads.
Make me a reasonable offer guys still got them
Re: AFR 195's with ARP bolts for sale
Part numbers?? Are they set up for roller cam or flat tappet?? max lift?? Close up picture of the damaged spark plug thread??? Pictures of the combustion area as well as the intake and exhaust ports??? straight or angle plugs??
Part number is 1040. They are angled plug and set up for roller cam. I was running a lt4 hot cam with it. There are guide plates installed for the pushrods and screw in rocker arm studs.
I should be able to take them. So they come with the valve guides, springs, valves, ARP head bolts, 3/8 rocker studs? This the basic new eliminator street head #1040 that AFR sells on their site? Do these have the springs for .60 or .650 max lift? If alls good, I should be able to take them.
Yup they are a full assembled head. They have the 3/8" stud. I can not give you a for sure on the lift. I want to say .600 I don't think they are .650 brother. Let me know what you want to do.
I went on Afr's website and looked up there contact info (http://www.airflowresearch.com/contact_us.php) I gave them the cast in numbers that are shown in the picture I attached. He informed me that these for sure are not the newer eliminator heads. They are the older style AFR's before the eliminators. He said if they were eliminator(s) they would have 1040 stamped on them. PM sent.
ambainb
04-25-2016 09:21 PM
