Custom grind Cam Motion camshaft, 50 street miles, $225
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Selling my blower cam that was custom ground by Cam Motion.
This was made from their premium quality alloy 8620.
Specs are:
Intake: 236° @ 0.050", lobe size 0.360", 0.540" w/1.5 rocker.
Exhaust: 244° @ 0.050", lobe size 0.350", 0.525" w/1.5 rocker.
LSA: 114°
ICL: 110°
Hydrolic roller style cam
8620 steel alloy material
Standard bearings and standard firing order
Overall cam:
Front of cam showing custom grind specs. Sorry for the flash. If needed I can take clearer picture again.
Here you can see the lobes are barely used at all.
Backside of cam. Numbers define spec.
If you want to confirm anything with the manufacturer, just click the link and give them a call. They will help you double confirm the specs listed here.
http://www.cammotion.com/spec-your-o...-own-camshaft/
This cam was $450 new. It has 50 street miles on it and less than a dozen dyno pulls.
I also have the RR, hardened pushrods and lifters for sale in other threads. Please PM with any questions. Thanks!
Specs are:
LSA: 114°
ICL: 110°
Overall cam:
Engine: LS3
Re: Custom grind Cam Motion camshaft, 50 street miles, $225
Dropping price to $225.
Engine: LS3
bump
Engine: LS3
No image of cam card.
all the info I have for the cam was listed in the original post. If you need any more data, you could call the manufacturer with the custom grind number. They were very easy for me to deal with.
Engine: LS3
Bump. Anyone have any tips on how to sell a cam with 5K miles?
eBay?
eBay?
Car: 1988 Pontiac Firebird
Engine: 400 sbc
Transmission: TH400
Axle/Gears: Ford 9" 3.50 35 Spline
I had to price mine down to $125 to sell it. Good luck with the sale!
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
It's hard to tell by the pics, but I'm guessing it's a retro roller, not OE roller cam?
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
It's a retro roller. Take a look at the second pic.
Engine: LS3
No. I was using an MSD pro billet unit.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
What did you make for power with this cam?
Engine: LS3
NA, about 400.
under booster I could not stop belt slip so I only made around 475 rwhp.
really depends on displacement, compression, heads, etc....
Engine: LS3
Moving to an LS3.
Sorry for the questions but I am currently looking for a new cam for my setup. How many lbs of boost were you running to experience belt slip? Was this cam in the 383?
Engine: LS3
Cam was in a 383 with old Trick Flow heads. 750 DP C&S Billet Aerosol blow thru carb.
Thru a T56, into a Moser 12 bolt.
I was shooting for 14psi. I didn't come anywhere close.
I was using a 12 rib belt on a Procharger (old style) TPI bracket. Stationary tensioner (problem). Bracket flex was real bad.
As soon as I started to make boost, slip slip slip. Bracket was made for a P1 @ 6psi, and I was running an F1 shooting for more than double.
My advice would be that if you are looking for a new cam, take the specs I posted and call Cam Motion (or whomever can give you good advice) and tell them what else you are running and what you want to do with the car.
They will tell you if the cam is a good fit. Best way to sort of if it will work. It is basically new and cost me over $400. It is in a bubble wrapped box in my basement waiting for the right buyer.
Let me know if I can help out in any other way.
Thanks.
Thanks.
Thanks.
Thanks.
Wont work well with my setup unfortunately. Pass it onto the next person man.
Engine: LS3
First $100 takes the cam. Just looking to clean out the basement.
Still wrapped in bubble wrap since I listed it. Basically new.
Engine: LS3
Price dropped to $50. Anyone want this?
Basically new cam. Retro roller that was in my Gen I SBC.
If I still have this in a month from now, it will be garage art I guess...
Engine: LS3
Cam is sold.
Almost unbelievable.
Heck, I would have bought it.
Heck, I would have bought it. Thread Starter
Engine: LS3
Timing is everything I guess.
Had it for sale on here for 3 years!
Finaly got sick of looking at it.
I think it would have been perfect for my 302 Chevy.
Tom91Bird
Nov 19, 2018 03:59 PM
kronos
64
Jan 4, 2009 10:47 PM
