..... For Sale ... Accel Pro Ram single plane EFI base manifold ported to 1206 gasket size with a modified stock plenum adapter to make it work under the hood of a C4 Corvette ... fuel rails included ... the fuel rails have AN-8 inlet and crossover fittings with AN-6 return line fitting all fully welded ... the bottom of the plenum was milled and had a 1" billet 4bbl carb spacer welded to the bottom and the side ports welded shut ... the inlet end is ported to accept twin 58mm or Mono-blade style TPI Throttle Bodies ... by using the stock plenum , ALL factory hook-ups are maintained ... This set-up fits under the hood of my '87 vette ... The plenum adapter may not work with ANY other base intake manifold unless you install a remote thermostat housing ... $700 plus shipping ... I also have a Lingenfelter 58mm TB available to complete the package if you wish ... $300 plus shipping ... Package deal on Throttle body and intake set-up $900 plus shipping ... :thumbs: .....
That's a cool hybrid! Retains kinda the TPI look with the flow and distribution of a 4 barrel intake. Hopefully whoever buys that will let the rest of us know how it compared to whatever setup they had. Glws
