[MN] Need 350 flat top pistons
Old Apr 19, 2010 | 10:43 AM
brian44t's Avatar
Car: 1987 IROC/Z28
Has anyone had their 87 or newer 350 bored oversize and saved the old pistons in the box from the new ones? I have a truck engine with dish pistons that I would like to raise the compression ratio with some flat tops. Willing to pay reasonable amount and shipping.
Old Apr 20, 2010 | 12:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Need 350 flat top pistons
What bore size are you after?
Old Apr 20, 2010 | 03:43 PM
brian44t's Avatar
Car: 1987 IROC/Z28
I am looking for standard size 350 but might be interested in oversize if the price is right.
Old Apr 20, 2010 | 10:48 PM
wesilva's Avatar
Transmission: 200R4
I've got six brand new standard bore 350 forged flat top TRW pistons. I bought six because I was building a 4.3 V6. 350s and 4.3s share the same pistons. V6 build never got off the ground. Both Jegs and Summit sell the pistons individually for $35 each. I'll sell you my six for $75 plus shipping and for another $70 you can have a full set of forged pistons. If your interested, I can send you pictures. They are new in the original box.
Old Apr 21, 2010 | 05:50 PM
brian44t's Avatar
Car: 1987 IROC/Z28
I am probably looking for more of a budget solution because this is not that great of an engine to begin with. I will keep yours in mind but I was hoping someone had some pistons they took out when they had their engine bored.
Old May 2, 2010 | 02:56 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
I have a set of Pistons and Rods out of my 1989 IROC-Z 5.7L TPI. They are standard bore. $60.00 + shipping
PM me if interested. Accept Paypal
Attached Thumbnails Need 350 flat top pistons-factory-iroc-pistons1.jpg   Need 350 flat top pistons-factory-iroc-pistons2.jpg
Old May 2, 2010 | 08:59 AM
wbspoon's Avatar
Car: 90,94,96 C4, 93 F 07 K3500
Engine: L98, LT1
Transmission: M6
90-92 are the only flat top L98 pistons.
Old May 2, 2010 | 09:27 AM
brian44t's Avatar
Car: 1987 IROC/Z28
I should have been more clear about this. I need flat top pistons to raise compression ratio on a 87 truck motor with larger combustion chambers.
Did the 90 - 92 L98 have higher compression ratio than previous L98's?
Old May 2, 2010 | 11:06 AM
wbspoon's Avatar
Engine: L98, LT1
Transmission: M6
Yes. The 90 - 92 L98 and all LT1 engines use a flat top piston.
Frozer!!!
Jan 19, 2024 04:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
BBSDesigns
Aug 11, 2015 07:39 PM
