looking for Performer rpm or air gap manifold
Old Feb 11, 2015 | 03:30 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Wanting to buy a Performer RPM or RPM Air Gap manifold for SBC. Must be spread bore, and in fair condition. Also looking for a Dual fan setup for my 1985 Firebird to get rid of the factory engine fan.
Old Feb 11, 2015 | 07:30 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: looking for Performer rpm or air gap manifold
I've got a dual fan setup with both the top and bottom mounting plastics. The top one has the typical cracked corner and is painted silver $60 shipped
Old Feb 11, 2015 | 08:00 PM
potterc32's Avatar
What did it come out of? I assume it's in good working condition. Can i get a couple pictures?
Old Feb 11, 2015 | 09:07 PM
Eric-86sc's Avatar
Engine: 305, 355
Can you send me an email address? I can get pictures up here but it's much easier through email. It came out of an 87 gta. The fans worked, the car was just sold as a roller and had the entire drivetrain removed.
Old Feb 12, 2015 | 09:58 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a nice Edelbrock RPM intake, for 86-earlier & ready for installation.
Send me a PM with an offer for the intake and your Shipping ZIP code. Then I can check into shipping and get back to you with some pictures of it.
Old Feb 12, 2015 | 02:58 PM
John in RI's Avatar
I got your PM.
Mine is a 7101 with a Square Bore. Sorry I can't help !
Old Feb 12, 2015 | 03:39 PM
potterc32's Avatar
Has anyone used a carb adapter to put a Q-jet on a square bore intake? If they aren't going to hurt anything or leak real bad, i think I could have some interest in a square bore intake... seems like there are 5 square bores to 1 spread bore for sale out there. None of the spread bores are RPM's or Air Gap manifolds..
Old Feb 12, 2015 | 03:51 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
I've used the Edelbrock adapter before with no issues.
Old Feb 12, 2015 | 04:27 PM
John in RI's Avatar
Correct,...
Many times,......
Old Feb 15, 2015 | 07:05 PM
Marc 85Z28's Avatar
I have an Edelbrock Performer RPM QJet intake, PN 7104.
Send me a PM if you're interested.
PS - A Performer RPM will not fit under a stock hood with any type of adapter or spacer.
Old Feb 16, 2015 | 04:28 PM
potterc32's Avatar
Found a fan/shroud from an LS1. Still in search of an RPM or Airgap manifold!!
Old Feb 18, 2015 | 08:00 AM
potterc32's Avatar
Found both parts!!! Thanks for the help!!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
