drop 350 in with what attached.
Car: 1995
Engine: 5.7
i am swaping in a 350 and i would like to know if it is easier to put it in with the headers already installed. i dont have air or ac. i bought the hooker 2460's headers. i was thinking of droping in the engine with headers and bell housing installed. then later put on the tranny. does this sound good. will the headers fit in with the engine at one time or will i not be able to put the headers on till after.
I just dropped a 305 in my cousins s-10 last night and there was no way to put it in with the headers installed. The steering shaft has to go in between them and the starter woulnt clear the frame. I know its not a camaro, but I would just wait untill its set in.
Yes, and you might want to put the spark plugs in before you tighten the bolts and after you set the headers in place. You also might want to put the starter in before you put the headers in.
Transmission: 4L80E/4L80E
I stabbed mine w/o transmission with the headers and spark plugs installed. Balancer, water pump, starter, flexplate, intake, etc., on; but not carb or distributor. And I have AC.
Tilt sling very helpful in this task.
Car: 1995
Engine: 5.7
well I have no air or ac and it looks like i have pleanty of room to drop it in with the exhaust on. i know for sure i can take out the engine with the stock manifolds on.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
when i did my engine, i dropped the engine in with the tranny already bolted up. there is no way that you can do it with the headers installed though. well, at least with my SLP headers, and i highly doubt it with any others..
-brian
-brian
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i did it, with headers, starter waterpump and distributor all on the engine, as a matter of fact the alternator was on it too.
i'm running the pacesetter headers from jc whitney, and i still have the huge ac box but no ac hoses or compressor
Eric-86sc
Aug 24, 2015 09:01 PM
