Help me decide my engine swap....
Old Sep 15, 2003 | 02:44 PM
FLYNLOW92rs's Avatar
I'm planning on turning my 305 TBI / Auto
INTO
350 TPI with a T56 Transmission....
I also plan to add a 4th Gen rear end & gas tank......
Can this ALL be done for under $5,000 or am i dreaming?
Any suggestions, comments, or such?
Old Sep 15, 2003 | 03:39 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Depends on the engine mods. 4th gen rears can be had fairly cheap. I am considering a 4th gen tank also. I do not know if the thirdgen fuel complex will fit into the tank. The 4th gen setup is different.
My guess would be yes buy by a slim margin.
Old Sep 15, 2003 | 05:01 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
What exactly is the point in putting a 4th gen gas tank in??? I know that all 4th gen rear ends are about 1 1/2" longer on each end.....so wider tires is now feasable. T56 would run....2000 from D&D Performance, of course a used one would be a better bet. Complete TPI can be had for under 1000, just gotta look in the right place. So I would say yes...it is feasable to do it for 5000. Just make sure you watch those nickel and dime pieces, they add up quick. Plus it also depends on what you get done to the engine. You want speed....you're gonna want to put on new heads and cam and intake. You want daily driving power....just throw the stock TPI in.
lc
Old Sep 15, 2003 | 07:19 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
plastic gas tanks that wont rust. 10lbs lighter.
weight saving mod
Old Sep 15, 2003 | 07:42 PM
TexasLT1's Avatar
Car: '92 RS
It could definitely be done. I would say the complete engine/tranny swap shouldn't cost any more than $4000 total, that leaves you another grand for a $200 rear end and however much the tank is, can't be too much.
Old Sep 15, 2003 | 08:06 PM
305RSlc's Avatar
weight saving mod
Plastic gas tank....there's an idea....does it just bolt up or are mods required???Higher or lower fuel capacity??
Lc
Old Sep 15, 2003 | 09:27 PM
Engine: 5.7 / 7.4
Link to the answers
looks like :
93-98 = 15.5gal
99-02 = 16.8gal
I'm not sure which years (if not all) have the plastic tanks, will do another search.
edit:
TexasLT1, please tell me you didn't crossover to the darkside
edit 2: other link, back to here
Old Sep 16, 2003 | 01:57 PM
TexasLT1's Avatar
Car: '92 RS
lol, the darkside huh? And which would that be that you speak of?!
Old Sep 17, 2003 | 09:36 AM
The TPI swap requires the fuel pump to be changed, so no sense in putting that old fuel tank back in there.....
Thanks for the input...
What's the going price on a used 350 TPI or what's reasonable?
Old Sep 21, 2003 | 11:38 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If you are having someone do the install, it will cost more then 5 grand.
For a high milage TPI 350, 1-1400 is the norm.
A used T-56 is the cheapest route.
BurlyChev
Aug 16, 2015 09:08 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
