Finally decided on a cam.,,, Drop in time**
Old Oct 6, 2003 | 08:34 PM
iroczman380's Avatar
Alright guys, After MONTHS of research (on this site) and multiple phone calls searches, and so on, Ive decided on a cam, and ordered it tonight, SO I CAN FINISH THE MOTOR!!!! Im going to Post the details, of the engine install and the cam install. Ill post pics as soon as I get a chance. Hopefully I can get it running in the next few weeks!!!!
Heres the setup for all you who care: (hoping for 12's)
-383ci 10.1 compression
-70's block
-Scat 9000 Crank
-Gm 5.7 Rods
-Speed Pro Forged Pistons
-Comp Cams 12-236-3 specs--Hydraulic 218/224 duration @.50,, 493/508 lift (w/1.6rocker) and 112LSA
-Comp Cams 812-16 Lifters.
-Vortec--62cc Heads (milled,bowl cut, spring upgrade, Ferrera Valves, 1.60 exhaust valves.)
-SDPC Vortec Tpi Base
-AS&M Runners
-FULLY hogged out Tpi plenum
-52MM BBK throttle Body
-Edelbrock TES Headers
-Custom Ypipe, OPen exhaust, (no smog laws in ks so!!)
-Air/Cat Delete
-2500 9.5" PRO BUILT Stall converter
-Custom Chip
-3.23 Gears
-POSI rear
Well I think thats it, and this time its a go. I just ordered the cam tonight, and I think its going to be killer. Ive got a couple Q's though.
First---of is this enough to run 12's??
Second-- Will The edelbrock headers, that I have on my 87 305 tpi motor bolt up to my vortec heads??? If not Then there up for sale. Nickleplated chrome. cost me 400.
Well Ill try to get pics soon, Ive got old pics of the short block that Ill post. Thanks guys for helping this build up become what it has become>
Thirdgen.org u---------
:yourock: :yourock:
Old Oct 6, 2003 | 08:39 PM
bohn333's Avatar
Car: 1987 Trans am
I'm running the Edelbrock headers with vortex heads and the fit just fine. It sounds like a good combo, i would go with a 3.73 gear though, to get the R's where they should be.
Old Oct 6, 2003 | 08:44 PM
yeah, I hear ya on the gears. its in the works,,,,,,
Old Oct 12, 2003 | 08:38 AM
Hey guys, Ive got the heads on,, and now Im trying to decide if I should Use 1.6 rockers or 1.5 rockers.
The lift of the cam is as follows Comp (12-236-3)
218/224 duration,, 462/477 lift,,,,112 LSA =w1.5 Rocker
With 1.6 rocker the lift goes to 493/508 lift. But does anything else change,, like the operating range of the cam. Duration????
Ive heard people tell me to put both on,,, so I dont know which one would be best.. Check my sig and above setup for all the parts im using. Let me knoww --
IROCZMAN380
Old Oct 12, 2003 | 01:17 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I think you should call a place and ask. But the durration would be longer and so would the openings, ask Kirch or gandy at school. Think of it this way if you dont already, your multiplying the cam by 1.5 and then 1.6 if you use the larger rockers. But i think most cam companies messure thier lift and durrations with 1.5 rockers, so do the math and figure out what your getting with the 1.6's.
Old Oct 12, 2003 | 07:37 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You could start with the 1.5s and work with it, tune it, and do some complete tests. Then swap over to the 1.6s and see what happens. I have had 1.5s work better in some engines. Mostly though the 1.6s will yield a little more power. Just try it and see if you have both sets anyway.
The duration won't change.....
Old Oct 12, 2003 | 08:16 PM
hey max,
Well see Ive called comp cams and summit and 2 summit guys told me that the duratiion and operating range (RPM RANGE) of the cam will drastically change. On the other hand I called Comp cams and Wheelermotorsports, and those 2 guys told me it would only effect the rpm range by like 1-150 rpms so basically it wont change the duration.. Which is what I thought. But I think Im gonna go with the 1.6 rockers just because I can get them from a friend for 100 bucks brand new. There harland sharp full rollers 3/8 stud. Well see how they do. Ive heard 1.6 put more wear on the valve train though. Anyone have experience with using the 1.6 rockers???? I think it should be alright. I also tried my setup in my new desktop dyno and got
381 horsepower @5300 Rpms
493 Ft Lbs Torque @ 2300RPMS
Sounds good to me Lots a torrque?? Hopefully Ill be pulling more horsies with the porting of the tpi,, and the work done to the heads. Looking for 400 at the fly.
Just wondering though,,, Is that typical for the torque peak to be at 2300RPMS??? Or is that just desktop dyno messing up???
It stays at an average of around 450 all the way to 5 grand but the peak is still at 2300???? Seems weird to me but, I dont mind.. Well if anyone can anwser some of the Q's in this post that would be greatly appreciated.. thanks guys.
IROCZMAN380
Old Oct 15, 2003 | 12:36 AM
Kiwi-85IROC's Avatar
From what I've read the 383's do produce max torque numbers from 2300 rpm onwards as you desktop sheet claimed with a milder cam like the one you're running. But they can very depending on your setup ie heads/intake/compression ratio etc.
Here are some examples:
Schmidt 383, from Chevy High Performance August 1996
350 four bolt block, .030 over
Scat cast steel 3.75" crank
Badger flat top pistons, 9.5 compression
DRS 5.7" rods
World products Sportsman II heads, 200cc
Competition Cams hydraulic cam, 211/221 @ .050, .442/.465 lift, 112deg lobe sep, Competition Cams Magnum rocker arms
Edelbrock Performer RPM intake, BG prepared Holley
Max Torque 503 @ 2800rpm
Max HP 410@5000rpm
Hot Rod/Summit 383, from Hot Rod March 1992
350 block, .030 over
3.75" stock 400 crank
5.7" production rods
Keith Black Hypereutectic Pistons, Compression 9.5:1
Crane Cams hydraulic cam; 236/246 @ .050, .510/.512" lift, 112deg lobe sep
AFR 190cc aluminum heads, 80cc chambers, 2.02/1.60" valves
Crane Cams aluminum roller rocker arms; 1.6 intake, 1.5 exhaust
Edelbrock Victor Jr. intake mainfold, Holley 750 double pumper carb
1-3/4" headers
Max Torque 435 @4750 rpm
Max HP 450@5750
Hot Rod 383, from Hot Rod January 1990
Manley forged flat-top pistons, 10:1 compression
Crane hydraulic roller cam: 222/222 deg @ .050, .525/.525 lift, 112deg lobe sep
Brodix -8 heads with 2.02/1.60" valves 73cc chambers
Edelbrock Performer intake manifold, Holley 750 carb
Max Torque 452@4000rpm
Max HP 431@5500rpm
Hope this helps
Trickskier
Jul 25, 2017 08:39 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
