'78 350 engine swap; check engine light on
Old Feb 21, 2004 | 12:38 PM
Cyrozis's Avatar
Car: 83 Z28
Engine: rebuilt 78 350
Transmission: not sure
Okay before i got my car the guy who had it rebuilt and bored out and everything from a '78 camaro 350. yet when i test drove it the check engine light was on and to this day (3 monthes later) ists still on. he said it was because he didn't plug in the sensor that it was hooked up to or something. i don't know. I was reading around that if the timing is off on the car the light will come on. I think my timing needs to be adjusted because at least once a week not always, the car will either diesel when turning off or just keep turning over heavily a couple times...hope thats the right terminology. hope someone can shed some light on this for me. thanks
Old Feb 21, 2004 | 01:44 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
1978 engines were not computer controlled. You will have to provide more detail on how the conversion was done, what electronics are in use, etc.
Old Feb 21, 2004 | 02:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Something isn't plugged in. I have a 350 out of a '79 Z28 in my car, and I know for a fact that all the computer controls can be used on the engine. Mine works like it was factory stock, and the check engine light only comes one when there is a problem... all the holes you need for computer stuff are there.
Old Feb 22, 2004 | 01:13 AM
Cyrozis's Avatar
Car: 83 Z28
hey thanks for writing some useful stuff. however i have no idea where to look for that specific wire. :-S or the computer. kinda new to the tinkering under the hood department. if you could explain where that would be alot of help.
Old Feb 22, 2004 | 08:14 AM
mikesz1984's Avatar
Car: 1984 z28
i had the same problem with mine when i put the 327 in my car, all it was was the choke wire was unpluged.
Old Feb 24, 2004 | 04:27 PM
Air_Adam's Avatar
Do you know how to get the error codes off the computer? If you do that, it will tell you were to start looking.
Old Feb 25, 2004 | 12:14 AM
Cyrozis's Avatar
Car: 83 Z28
no i have no idea how to get them off the computer. i don't even know where the computer is at. sorry the innards of the car are still kinda dim for me. but im learning fast. hows it done?
Old Feb 25, 2004 | 02:06 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Is the car a 83 or a 78 ? You have me confused, but if it is a 83 I can be some help to you for sure.
Old Feb 25, 2004 | 02:24 AM
Cyrozis's Avatar
Car: 83 Z28
its an '83. the only thing from 78 is the 350 that i know of.
Old Feb 28, 2004 | 04:50 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I got a 1969-72 350, 4 bolt main. No sensors were hooked up. I just removed the bulb. I check my engine at least once a week, so as long as you keep on the maintence, all will be good
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
