Fuel pressure regulator?!?
Old Apr 28, 2004 | 07:39 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ok so im dropping the fresh new 355 this weeken, runing the same tpi pump with a holley 3 port pressure regulator, i have 2 ports hooked up now to it, one is blocked off, one for fuel from pump and one for puel to the carb with lower pressure, the blocked one i guess i should hook up to the return line, or leave it blocked...what do i do...this is what it looks like.....the fuel paths at last
out - - out
I
in
Old Apr 28, 2004 | 07:53 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
I can't say for sure how the holley works but my Mallory works like this:
4 ports
1 for fuel in (hi pressure)
1 for low pressure out (to carb)
1 for remaining pressure out (back to tank)
1 blocked
Let me also note that with my AFPR I could not get the PSI below 10 and had to add another low pressure (3-12PSI) regulator inbetween the carb and the first regulator to get to the right PSI.
Hope this helps ya
Old Apr 29, 2004 | 07:38 PM
Charged350's Avatar
Car: 87 IROC Z28
thanx, ill play around with it this weekend when i drop the motor so we shall see...
Old May 3, 2004 | 12:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You should probably find out before you run the engine. You absolutely need a return line back to the tank or you'll prematurely burn up your fuel pump. A regulator fuel return port will have a valve to control fuel flow. If you can see straight through then it's just another fuel feed - it is not a fuel return port. If this is the case then you need a different regulator.
Old May 3, 2004 | 01:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The "typical" Holley reg has an inlet port and two outlet ports (one for each bowl, or one to carb and one to pressure gage), no return port.
You need one that regulates pressure by controlling the amount of fuel returned to the tank.
Old May 3, 2004 | 06:56 PM
Charged350's Avatar
Car: 87 IROC Z28
yeah, ill run teh holley to get it runnin ya know, but i need teh better one, but i donno which one, i heard mallory is pretty decent with their 4 port regulator...which one tho....any links, numbers for me...thanx guys...
Old May 4, 2004 | 01:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Personally, I wouldn't run it at all like that or you can risk burning up the fuel pump. You'll be operating the car for at least 30 minutes just for initial break in. I'd rather change a regulator than change a fuel pump!
Old May 4, 2004 | 07:47 PM
Charged350's Avatar
Car: 87 IROC Z28
hmmm...no need to break in the motor, its already been broken in adn all,
but i wanna get a return stule regulator, but which one...i donno...anyone know...
Old May 12, 2004 | 11:17 PM
IROC_385Z's Avatar
Engine: SBC 385
Here it is.
...Taken from a tech document at www.thirgen.org
AFPR option: There are two AFPRs at the time of this writing that I know of. One is made by Mallory (p.n.: MAA-4309) the other by Barry Grant (p.n.: 132-171021). Again, which is better is mostly personal preference. Note that there are three lines from the fuel tank on the drivers side under the master cylinder. One is fuel delivery, one fuel return, and the other goes to the charcoal canister behind the headlights. The fuel delivery line is slightly thicker than the return. Go to your local hardware store and buy some 3/8" pipe thread to 3/8" hose nipple fittings, and put one in each port of the AFPR with a good coat of thread sealant. Plumb a hose from the fuel delivery line to the suitable port on the AFPR, and do the same with the return. Finally, run a line from the pressure port on the AFPR to the carb. Remove the hose that's on the line going to the charcoal canister (remove the whole canister if you want), clamp a length of 3/8" hose onto the end of the hard bent line, and rout it out of the engine compartment somewhere. Mine exits in front of the left tire. This is necessary to vent pressure buildup inside the tank.
www.thirgen.org
Old May 16, 2004 | 01:51 PM
Charged350's Avatar
Car: 87 IROC Z28
it runs nice with the holley, but im gonna geta mallory one this week...
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
