Swap almost done, need vats help.
Old May 21, 2004 | 09:07 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Okay, the 305 tpi is in my car, hooked up but wont crank.
I have no juice coming from the purple wire, and i assuming it is vats related.
Heres a little background on yhe swap.
We used the complete motor and harness from an 87 trans am. Everything went off without a hitch, until i turned the key and nothing happened, i did not even get a security light when i turned the key on like i used too.
Well, we grounded the black and yellow wire from the vats relay(or whatever it is)
after doing that, the security light would come on, and the relay would click, but it would still not turn over.
Any ideas, do i need to solder in a resistor, if so, where. I did a search, but the majority of answers were about lt1 swaps.
Old May 21, 2004 | 11:30 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
With no vats setup on the old 87 can't we just completly bypass the vats setup by removing all of the relays, decoder box, and associated wires from the 91 bird?
Or is that more problematic than simply figuring out how to make the 87 ECM recognise Vats, and then bypass it with a resistor.
Old May 21, 2004 | 11:34 AM
9D1BURD's Avatar
Car: 1997 Z28
If we can get the ecm to see the signal, bypassing wont be required, as the system functions properly.
Old May 21, 2004 | 03:36 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
I read something yesterday about bypassing VATs and it said you need to messure the resistance on your key, then get an appropriate resistor to connect the wires with to bypass it. Once i find the page again I'll post it here.
Old May 21, 2004 | 03:38 PM
Car: 1987 Trans Am
Engine: tree-fiddy
post count ++ lol
here's the link
http://sethirdgen.org/vats.htm
Old May 21, 2004 | 09:45 PM
Nikole's Avatar
Car: 1992 RS
TTT
Old May 25, 2004 | 09:03 PM
FruityOne's Avatar
Any luck with the wiring Tim?
Old May 27, 2004 | 01:42 PM
9D1BURD's Avatar
Car: 1997 Z28
Yep, painless harness is on.
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
