350 crate
Old Jul 15, 2004 | 02:40 AM
88'iroczzz's Avatar
Car: 88 iroc z28
Engine: 305 pos
350 crate
any suggestions on a good place to get a 350 crate cheaper price range???looking for atleast a 300hp engine?
Old Jul 15, 2004 | 08:52 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 350 crate
Take a look a www.allchevyengines.com
Old Jul 15, 2004 | 04:30 PM
elementz's Avatar
Car: 1991 rs black
Engine: 350 zz4.
are these engines california emissions certified?
Old Jul 15, 2004 | 04:36 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
elementz, since you asked if they're california certified, i'm assuming you're from california ...
if you want to swap in a V8 legally, there's alot more to getting it through smog for you, since you've got a 6 like me... i've done a bit of research on the topic and basicly what you need to have is an engine from a passenger car of your year or newer, and all of the smog equipment that came with it in good running order, then you have to take that to a smog referee... thats my little cliffnotes version...
I suggest looking into an LB9, L98, LT1 or even the LS1 depending on how much you want to spend
Old Jul 15, 2004 | 05:03 PM
elementz's Avatar
Car: 1991 rs black
Engine: 350 zz4.
so theres no hope of me swapping in a new crate motor and passing emissions? thats what i would like to do but i'm starting to realize thats not going to happen
Old Jul 15, 2004 | 08:08 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
most of the crate motors out there were intended for pre-emission vehicles (50's up to mid 70's) so there are no emission provisions on them, but if you live in a part that has no emmission testing...you can have at it.
Old Jul 15, 2004 | 08:16 PM
DJP87Z28's Avatar
Swapped in a 350 crate and installed all the Emission Controls from the old 305 TPI and passed two Ohio E-checks with no problems. The last test they gave a quick pass the car was so clean.
Old Jul 15, 2004 | 08:59 PM
I knew there was a way around it but to be honest, I wasn't quite thinking a lot about swapping over the emission equip...good info DJP.
Old Jul 17, 2004 | 12:35 AM
82maroz28's Avatar
Car: 82 camaro z28
Engine: 305 ci
Elementz,
You're wondering if swapping in a 350 will be able to pass smog in CA, well, I'm wondering the same thing for myself since I'm doing the same thing. It's all too common. https://www.thirdgen.org/techbb2/sho...hreadid=245608 is a post of the work I plan to do to mine. And hey if I don't pass SMOG in CA there will always be a friend around who will. But I'll see if I could put my old emission control things back onto the 350 only when needing to pass SMOG, of course. I don't have to worry about SMOG until August of next year so I see how everything goes.
Old Jul 18, 2004 | 05:56 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
http://www.goautocenter.com
There was a guy a while ago who bought the 350 TPI and he passed Cali emissions just fine. I purchased the same motor, but through aluminum heads on it.
This place has some pretty good deals.
Vojtush31
Oct 11, 2015 01:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
