engine serial number
Old Dec 19, 2004 | 01:41 PM
brian_27909's Avatar
I'm in the process of rebuilding a 350 to install into my 91 RS.
I'm trying to get some history on the engine
I've decoded the assembly code, but i've not been able to decode the vin stamp that is on the block
Engine Assembly Date / Suffix Code
VO602TKB
listed vin stamped next to the above engine assembly information: C6B165511
I really just need to find a way to decode the vin listed, as i have done the assembly date
Old Dec 19, 2004 | 02:02 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: engine serial number
VO602TKB
vin C6B165511=
C=Lansing
6=1976
B=Baltimore
165511= Production sequence of vehicle VIN
info resorced from http://www.nastyz28.com/sbchevy/sblock.html#cdate
V0602TKB+
V=Plant=Flint
06=Month=June
02=Day
TKB= Engine suffix code.=1976 TKB 350 conv.cab L LS9 165 4 C-10 & 1500
Old Dec 19, 2004 | 02:23 PM
Re: Re: engine serial number
Originally posted by THEGENERAL
vin C6B165511=
C=Lansing
6=1976
B=Baltimore
V0602TKB+
V=Plant=Flint
06=Month=June
02=Day
thanks for the info ... don't know how i missed that page
Old Dec 19, 2004 | 08:39 PM
THEGENERAL's Avatar
No problem glad i could help ya out...
What are your plans for the engine??
Heads?
Cam?
Intake?
etc....
Old Dec 19, 2004 | 09:07 PM
Heads?
Cam?
Intake?
etc....
Well, this is going to be my first complete rebuild, as all i have are the block and heads, (no crank, cam, nothing)
i've got a few friends to "guide" me, and help out with this project of turning the Camaro RS into a Drag car.
The heads will be milled about 30 - 40 off them, alum intake with holly double pumper, not sure about the rest.....
any good websites for turning a block into one hell of a motor?
Old Dec 19, 2004 | 09:27 PM
THEGENERAL's Avatar
search around on here there are lots of guys doing the same as you and have many ideas of cam and head choices...
are you going to make the 350 into a 383 stroker??
Old Dec 19, 2004 | 09:49 PM
ljnowell's Avatar
What kind of heads are these? Do you have a casting number for them? Most heads that need milled that much for compression probably dont flow enough to be useful in a performace build anyway (ie 882, 993, 997, etc.)
Old Dec 20, 2004 | 04:55 AM
Heads Information:
Casting Information
333882.....74-80...350/400......76cc chambers
Old Dec 20, 2004 | 10:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ewwwww....
Get some real heads.
Old Dec 20, 2004 | 10:54 AM
THEGENERAL's Avatar
Originally posted by five7kid
Ewwwww....
Old Dec 20, 2004 | 12:17 PM
ljnowell's Avatar
Heads Information:
Casting Information
Any build centered around those heads will be a real dissapointment to you. Those are among the worst of the worst.
Old Dec 20, 2004 | 03:00 PM
mightymaro94's Avatar
you want good heads find a set of 906 vortecs of the 97 suburbans i think or whatever that big monstosity of a truck is, they flow almost as good as darts, and you can find em in the junk yard most of the time
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
