Oil Pan Fitment
Old May 7, 2005 | 09:15 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Oil Pan Fitment
Okay just bought a 355 out of a 67 camaro. I was thinking of things that might be a problem when I thought about the oil pan. Could anyone tell me if a 67-69 camaro oil pan will clear the crossmember on a 88 Iroc. Thanks for the help.
Old May 8, 2005 | 11:42 AM
sellmanb's Avatar
Car: '86 Berlinetta
Oil pan should fit as long as it's not too deep. Also make sure that where it "lips down" is about the same angle as your stock one.
Old May 8, 2005 | 07:21 PM
Does anyone know for sure. And if it does not fit will the 305 oil pan mount on this block.
Old May 8, 2005 | 07:29 PM
sellmanb's Avatar
Car: '86 Berlinetta
n/m
Old May 9, 2005 | 10:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A '91 305 oil pan won't fit a '67-'69 350 block.
Old May 9, 2005 | 12:18 PM
JesasaurusRex's Avatar
Ya the 91 305 pan has a 1 piece rear main seal while the 67-69 350 has a 2 piece rear main seal. Also the dip stick location is flip flopped.
Old May 9, 2005 | 07:54 PM
My car is a 88 so the ooil pan will fit. Right.
Old May 9, 2005 | 08:10 PM
the 305 pan will, if its the original motor.
Old May 9, 2005 | 08:38 PM
Old May 10, 2005 | 10:29 AM
five7kid's Avatar
Somebody doesn't seem to be following the dancing monkey - The year of the car ('82-'92) doesn't matter. The year of the engine does matter.
If the 350 out of the '67 is of '67-'79 vintage, then no factory 3rd gen oil pan will fit the block - period. You need an oil pan made for that older type of block.
Most likely, the oil pan that is currently on that engine will fit in your chassis just fine. But, with an engine that's almost 40 years old, it's impossible to say what modifications may have been made to it. Therefore, whether or not the oil pan that was on the engine when it came out of the '67 will work in an '88 is next to impossible to say without actually seeing the pan.
Old May 10, 2005 | 06:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A 2ndgen Camaro oil pan fits just fine. Thats what I used.
Old May 12, 2005 | 08:55 PM
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
