Big block 427 PLEASE HELP!!!!
Car: 91 Camaro RS
Engine: 5.7
Im in need of some help. I have a new big block 427 and I want to put it into my 91 third gen. What modifications id any do i need to do. I have a custom built 400 turbo trans to go with it. one way or another i am going to get the motor in. Is there any help anyone can offer? will i need to cut the fire wall? move the motor mounts? I beefed up the suspension so it can handel the motor. The motor its self is pulling about 850 hp. It contains a Eagle forged steel crank, Eagle H-beam connecting rods, JE forged pistons with a 10:1 compression, Dart PRo 1 aluminum heads, Holley cam, solid lifters and roller rockers, Weland 8-71 supercharger, dual 1095cfm Demon king carbs. The heads have been ported and polished to the max. im not sure what it is. But over all it is one mean motor. So if you have any ideas or sugestions that can help, please inform me. Thanks
Transmission: 4L80E/4L80E
There's a sticky at the top of this forum with links to information about BBC swaps. Of course, with 850 HP, you're above and beyond the typical street-driven BBC swap.
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
hopefully you haev money left over for suspension, tires, rollcage, chassis stiffening, etc
Car: 91 Camaro RS
Engine: 5.7
Well the good news is the motors is in. everything fit very very snug. the only mods i really had to do was the motor mounts and i recessed the fire wall in about an inch where the distributer is located. The motor mounts were fabed up by a friend of mine. He had a very good idea. I will try and get pics of the motor mouts. Also I replaced my rear end with a 4:10 locker. That took some time! I ran the car for the first time the other day. I noticed a crap load of body roll durring acceleration. Going to need to stiffin the frame! New and bigger tires are a must! The 15x10's diddnt cut it. the front end pulled up off the ground about 6 inches from what my buddy had said. i wasnt pushing it too hard because of the engine break in. just as the frot end lifed up the tires let loose and lost traction. Oh i almost forgot. I made up a set of custom headers from a header kit i purchased from Jegs and i replaced the fuel pump with a new holley pump. I will have to give you more info later. Thanks
RyanJB
Sep 14, 2015 03:39 PM
