305 to 350
Old Apr 2, 2006 | 12:14 AM
joshs 89 iroc's Avatar
305 to 350
I have a 89 305 tpi and want to build a 350 for it, I think depending on the years there are different head to manifold bolt patterns. So, I was wandering if you guys could help me figure out which year 350 would work.
Old Apr 2, 2006 | 12:48 AM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
im going to guess a 350 from around the same time period as your 305
Old Apr 2, 2006 | 11:22 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
'86 + heads...
Old Apr 2, 2006 | 12:45 PM
chesterfield's Avatar
Car: Pontiac
87 and up heads and 86 and up block.
Old Apr 4, 2006 | 01:41 AM
iroc22's Avatar
87-up are roller blocks
85-up are 1 piece rear seal
LT1/LT4 blocks wont work
Corvette heads and intake are different bolt patterns (they use pre-87 pattern) and lack EGR, so if you want to do the Corvette heads, get a Corvette intake
Also you'll need the knock sensor and ESC from the 350
Old Apr 4, 2006 | 12:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'86-up are 1 piece RMS, actually.
'88-up self-aligning rockers.
Sure is hard keeping all this straight, isn't it?
Old Apr 4, 2006 | 01:03 PM
I Believe the 305 and 350 camaro Intake manifolds are the same, But I was going to use Aluminum heads and probaly a edlebrock TPI intake. I was wondering do I get standard or center bolt heads and intake, and whats the difference
Old Apr 10, 2006 | 01:38 AM
iroc22's Avatar
Yeah it sure is, makes it even harder to match all the correct parts together when you're just a beginner.
What type of heads?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
