Sensors in heads?
Old Sep 12, 2006 | 12:30 PM
SlowCamaro88SC's Avatar
Sensors in heads?
I'm in the middle of my 88 305 to built 84 355 swap, and the 305 heads had sensors in them, the 84 obvioiusly doesn't, but i need to install them. only problem is that the threads for the holes on the 84 355 are a bit larger than the holes on the 305s and just don't thread in.
what do I do??
also there is this copperish looking tube that sticks out of the block, on the back, on the 305 it was attached to some solenoid, in the 355 it's just a tube, what is that and what is it for?
Old Sep 12, 2006 | 12:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use pipe bushings for the sensors in the heads.
Where is the tube sticking out of the block?
Old Sep 12, 2006 | 06:02 PM
it's just behind where the LIM mounts, was on both blocks. though my 305 one had a solenoid of some sort attached to it.
Old Sep 12, 2006 | 06:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oil pressure sender/switch.
Old Sep 12, 2006 | 06:42 PM
damn, so I gotta use it huh? I can't just block it off? dang I need to found out what happened to my 305, cuz it's long gone. -- my dad hauled it off one weekend when I wasn't around.
then whats in the heads?
Old Sep 12, 2006 | 07:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you don't want to use the oil pressure sender, or you want to use the other port on the side of the block, replace the tube with a pipe plug.
The driver side head has the coolant temperature sender, and the passenger side head may have a fan switch.
If you're missing any of these, you can get replacements over the counter at any parts store.
Old Sep 14, 2006 | 03:51 PM
a plug? I can do that, I assume I can find them at a parts store or a hardware store?
i do have them, but where can I get a "pipe bushing" to adapt mine to this other block?
Old Sep 14, 2006 | 06:00 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You need two 1/2" x 3/8" black steel bushings, you can get them at your local home depot or plumbers supply. Shouldn't cost more than a couple bucks.
Old Sep 14, 2006 | 06:06 PM
thanks john.
Old Sep 14, 2006 | 06:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They don't have to be black steel, they can be any metal. Brass is most common. Auto parts stores will have them, too.
Old Sep 15, 2006 | 02:49 PM
thanks
9192camaro
16
Feb 3, 2019 12:21 AM
Chuck84TA
Jul 15, 2016 09:05 PM
bamaboy0323
Sep 3, 2015 06:07 AM
