oil filter adapter
Old Oct 13, 2006 | 11:16 PM
marcika's Avatar
Car: 86 IROC
Axle/Gears: 9 bolt Posi 3.45
oil filter adapter
Hi, I'm installing a 350 TPI into my 86 IROC. I'm just about to put the oil filter adapter plate on but I'm not sure if i'm suppose to have a gasket behind it or not? any help? does anyone know what size and length bolt goes in there?
thanks
Thomas
Old Oct 13, 2006 | 11:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you talking about the oil cooler?
Old Oct 13, 2006 | 11:41 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the oil filter adapter should have come with a gasket, at least every one i've ever installed has.
Old Oct 13, 2006 | 11:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're talking about the oil cooler, then there should be an O-ring between it and the block. If you're talking about the oil filter adapter, then there is no gasket between it and the block.
Old Oct 14, 2006 | 11:09 AM
marcika's Avatar
Car: 86 IROC
its not the oil cooler. its a chunk of metal that bolts to the block with two bolts. and then you screw your oil filter onto it. the shop that rebuilt the engine took it off when they stripped it. I'm just trying to figure out if I need a gasket between the part and the block.
Old Oct 14, 2006 | 11:12 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No gasket for that.
Old Oct 14, 2006 | 11:38 AM
marcika's Avatar
Car: 86 IROC
ok thanks, I'll take your word on that.
thomas
Old Oct 14, 2006 | 02:48 PM
xpndbl3's Avatar
Car: 1984 Z28
all my oil filter adapters came with gaskets to mount between that and the block. Perhaps they're not needed but all mine have them, done 6 or 7 sbc now and they always had a gasket in the packaging.
Old Oct 14, 2006 | 03:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't think you're talking about the same thing.
Old Oct 14, 2006 | 03:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my filter adapter has the o ring, and I used it.
Old Oct 14, 2006 | 03:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's nothing wrong with using it on an aftermarket adapter like that one, but the stock adapter doesn't use a gasket because it's not an area where a gasket is needed. The pressure difference between the two sides is pretty low, just the pressure drop across the oil filter, and any tiny amount of oil that did leak past it still ends up going through the engine.
By the way, the bolts should be about 5/16-18, around 1 1/2" long, but with smaller heads than normal.
Old Oct 15, 2006 | 01:21 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Mine didn't have a gasket stock, so I didn't put a gasket on it after I put it back on..? My rebuild book never mentioned a gasket, and i've never bought the part new so...
Old Oct 15, 2006 | 03:13 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
None of the stock ones I have ever seen have ever had a gasket so I have never put a gasket on there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
