porting your own heads
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
okay so hear is the deal i posted something about my 350 with 305 heads the other day and was told to get the 14101081 casting well it turns out that there are a set of those heads on my 305 thats in my car now so i will be removing them and switching engines so i was wondering if it would be a good idea to port them myself while they are out or if it is just a headache considering they are cast iron please give me some feedback or a how to or just call me stupid for even considering it im sure it will all help.
thanks for reading
thanks for reading
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: None
Transmission: none
Re: porting your own heads
well i already have the 081's and dont really have money but i have a 600 cfm edelbrock and 081's flow 195 cfm at .500 lift on a bench test so do i really need to do anything to them because those are the ones im using unfortunately unless domeone can donate some also what do i do to sort of refurbish my 081's?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You aren't gonna brake your budget if you go junkyard hunting and get yourself some TPI heads. I don't know the numbers, they may be the numbers listed above, but they are worth it. They make an improvement just swapping them to a 305 with TBI that you can feel. You won't spend much money; it will just take time to find them - but you CAN FIND THEM. Take your time now while stuff is apart.
You'll be happy you did...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Holy cow.... Thanks Five7, sometimes it's painful to watch...
Yes port them yourself. Read the thread by sitting bull, and posts by F-bird'88 and the others that have posted about it. Cast iron is just fine to port. It's worth it.
Transmission: 4L80E/4L80E
On the Board is this forum called "FAQ" - that stands for "Frequently Asked Questions". In it you'll find posts about things that are often asked - such as, "Differences between 305's and performance tips". Interestingly enough, you'll find information about what heads are the best to use, porting them, etc., etc., etc.
Another tactic is a simple search for things such as "416", "081", "181", "601", "porting", etc. Amazing what will come up.
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
