305 to 350
Old Apr 9, 2007 | 01:11 AM
95foxbigblock's Avatar
305 to 350
hi guys, i recently bought an 85 z28 w/ 305 and 5 spd. well i was woundering iwould a 350 swap be pretty straight forward? both motors are/would be carbed.
Old Apr 9, 2007 | 02:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
How straight forward it would be depends upon the vintage of your 350. Do you know what you have, exactly? Head and block casting #'s would be good to know.
Old Apr 9, 2007 | 03:19 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: 305 to 350
It can't be any more straight forward. Just get rid of all the crap you don't need under the hood. You should have a v belt system so deleting stuff should be easy and if you don't live in a smog state you shouldn't have to worry about being hassled. Just as long as all your brackets fit on the 350 you won't have a problem.
Old Apr 9, 2007 | 02:44 PM
five7kid's Avatar
Re: 305 to 350
Actually, brackets are the least of the concerns. Dipstick location, rear main seal type, intake mount bolt pattern, and the like, are why I asked.
There isn't much "smog stuff" to be removed.
Old Apr 13, 2007 | 10:34 PM
Re: 305 to 350
sorry it took me awhile to reply, what year would you guys recomend to get, im also going to be using an m-22 with the swap. the car will not have a/c,power steering, or smog. on the ignition will i have to change any thing besides the distributor, and also i have a rebuilt holley q-jet with the tps and m/c solenoid, could i use that on it without any problems to save some money for a while.
thanks for any and all help
Old Apr 13, 2007 | 11:29 PM
five7kid's Avatar
I wouldn't worry too much about the year of the engine. Whatever you get, you can overcome any of the small issues that exist. Later roller lifter one-piece-rear mains seal blocks seem to be of better quality than older engines.
Old Apr 14, 2007 | 12:12 AM
Re: 305 to 350
thanks for your help this seems like it could be done pretty easy. cant wait for it to warmer out
Old Apr 14, 2007 | 11:55 PM
viridis's Avatar
Car: 1992 rs camaro/68 nova
Engine: 305 tbi/ 383
Transmission: stock/ th350
Axle/Gears: stock/stock
Re: 305 to 350
good luck! I'm tearing into my camaro now to replace the tbi 305 with a carbed 383.... Will be my first motor swap of many I'm sure...
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
