Is this stock or a swap.
Old Jun 28, 2007 | 12:53 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Alright i foudn a firebird that im looking to purchase. But im confused.... Ive looked and in 87' i havent been able to find a car that has a "307" in it... So im confused. Either this guy doenst knwo what it is and its actually a 305... Or it got swapped into it?.... How can i tell if its a 307 or a 305? and what cars were equipped with the 307?
Old Jun 28, 2007 | 01:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Is this stock or a swap.
depends on which 307 you are talking about
chevy 307 was made from 68 to 73
and then oldsmobile had the 307 for a long long time from i dont know when, to at least the late 80s
both engines are nothing much more than smogger peanut engines, basically as bad as a 305
although id rather have the chevy 307 than any of the other two if i had to choose
ive had a couple 307 chevies, first one was original in a pretty nice all original '68 c-10 pickup, the first one i ever had anyways, ran great,
neither engine came in a third gen f body anyways
if its a chevy engine then its probably the 305
get the numbers off it
you wont know til you run numbers, youre not going ot be able to tell just by looking at it other than if its a chevy or an olds
but you can guesstimate by the harmonic dampner, if its the really wide one then its a 267 or 305 or later years 350 possibly, if its a real skinny one then its 265 283 302 307 or 327 or early first years 350 or something else early 70s or earlier
350 chevy engines used three different widths of dampners over the years
if the engine looks non-original/hacked in/missing smog/computer stuff and is painted anything but black then its hard to say what it is
good luck
Old Jun 28, 2007 | 01:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Could also be a .010 over 305.
Old Jun 28, 2007 | 02:46 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Well i talked ot the guy and he said itw as not original... However it was never completely installed... so im wondering how difficult it would be to get the 307 running inplace of the original 305. Or is this somehtign i would need to pull the engine and get a 305 in its place?
Old Jun 28, 2007 | 03:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's no reason you can't get a 307 running in place of a 305. There will be some "issues", but nothing that can't be overcome.
Old Jun 28, 2007 | 05:49 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
is there exhaust ?
radiator ?
battery cables ran to the other side of the car?
(since oldsmobile starters are on the opposite side than chevies)
if its missing these and other parts then you may have more of a project than you would like
and if you went to put a chevy engine back in it then you would have to swap the tranny if its not the 10 bolt universal one
because chevy has a different pattern than the rest of GM
v-8 and some v-6 anyways
or is it a chevy 307 in it ?
good luck
Old Jun 28, 2007 | 09:46 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Originally Posted by Randy82WS7
is there exhaust ?
radiator ?
good luck
exhaust, radiator, and cabels...Not sure if its an olds or chevy... I found out it needs a new starter or selinoid... Then it should start...
Old Jun 28, 2007 | 11:34 PM
five7kid's Avatar
More than likely it's a Chevy. Whether or not it's a 307, well, still impossible to tell from what you've given us.
Old Jun 29, 2007 | 02:59 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Need block casting numbers. Should be driver's side at the backend of the block, that flat area behind the head.
Old Jun 29, 2007 | 08:43 AM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Alright thank you. I asked him if he could get me the numbers but he didnt knwo were to look so i told him id ask were they are and see what he could do. Now i know so hopefully ill have it today to tell you guys.
Genopsyde
Oct 7, 2015 08:35 PM
Warlocksirix
Sep 3, 2015 12:26 PM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
