Help please!!!! a carba on a lt1??? please help!!!!!!!!!!!!!!!!
Old May 8, 2008 | 08:32 PM
angelz28's Avatar
my friend have a lt1 out from a caprice 96. But no computer, only manifold and fuel inyectors.
ok I donk know nothing about fuel inyection ok!
i know that summit sales NAL-24502592 ( carb manifold), but what about the distribuitor?? does my edelbrock carb fits??
what about my heathers???
__________________
Old May 8, 2008 | 08:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Help please!!!! a carba on a lt1??? please help!!!!!!!!!!!!!!!!
LT1s use the same headers as a SBC, but they have D-shaped ports. Hedman makes headers for that style port IIRC.
GM performance parts is the only mfg of a carb manifold for the LT1 as far as I know, but its designed to use any normal 4bbl carb - Holley, Qjet, Edelbrock, etc.
Any SBC distributor can be used.
Old May 9, 2008 | 07:41 AM
angelz28's Avatar
Just like that??
Old May 9, 2008 | 07:33 PM
Air_Adam's Avatar
Originally Posted by angelz28
Just like that??
Just like that
Old May 10, 2008 | 01:11 PM
angelz28's Avatar
what about the water pump?????
can i use the traditional??
Old May 10, 2008 | 02:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Nope, you have two main choices
LT1 cam driven (you wont have any trouble using it.
LT1 stock housing with electric pump that bolts into the front and you plug the rear drive hole, the pumps come with the plug to fill in said hole.
Old May 10, 2008 | 05:22 PM
angelz28's Avatar
ok
Old May 10, 2008 | 05:29 PM
angelz28's Avatar
so. I take the old manifold, put the new one! and carb and distribuitor.
bolt on and go!!
is that it?
Old May 10, 2008 | 05:50 PM
Air_Adam's Avatar
bolt on and go!!
is that it?
Pretty much, yea. Its not alot different than the TPI guys changing over to a carb, just the particulars are different. Its pretty straightforward.
Oh, one thing I did forget to mention - on the LT1 timing cover, you will have to plug the hole for the Optispark, as you'll no longer be using it since you have an old style distributor. I think just a large freeze plug should be fine.
Old May 10, 2008 | 08:30 PM
angelz28's Avatar
thanx man!!
Old May 12, 2008 | 02:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It would be cheaper to find a used LT1 harness/PCM set-up than it would be to convert to carb.
Keep it like God intended, or sell the engine and get a "regular" SBC 1 to put in your car.
Old May 12, 2008 | 02:27 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You would end up with more in the kit to convert it to a carb than doing like five7 said and buying the PCM and harness seeing you have everything except that.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
