My L98?
Old May 28, 2008 | 07:01 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
My L98?
Well, i've been reading on TPI, and it has both its ups and downs. Tho my L98 is 90% built, and ready to run.. i am starting to think about going with a modified LT1 intake, and selling the TPI intake setup, and not loosing all that much money.
Just need to figure a few things out first.
The 88 Iroc this engine is going in had a 305 TPI.. obviously MAF, and want to use the same harness/ECM. I already have a L98 thermomaster prom to run a 350.
If i buy an LT1 intake, and send it to LT1intake.com, have them mod it for my heads and block off the MAP port, Will everything function as if i were to be running my MAF TPI? i will use the same throttle body and sensors, maf sesnor from the TPI..etc. I found a ported LT1 intake that is sick for $150 on the bay, im thinking hard about doing this.. so let meh know what hell i would run into doing this!
Old May 28, 2008 | 07:20 PM
Engine: THREEFIDDY!
Re: My L98?
Also, just tried to email scott@lt1intake.com, got a reply from hotmail saying no such email.. Does anyone know whats going on with that?
John
Old May 28, 2008 | 10:22 PM
Engine: THREEFIDDY!
Re: My L98?
bumpers
Old May 29, 2008 | 04:25 PM
Engine: THREEFIDDY!
Re: My L98?
NoH BoDYY>??
Old May 29, 2008 | 06:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: My L98?
You might have better luck getting an answer to your question on the 'TPI' or 'EFI' specific boards, instead of the engine swap board here. I'd like to help you, but I don't know enough about it to tell you anything with any certainty.
Good luck!
Old May 29, 2008 | 07:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: My L98?
I've heard lt1intake.com is no longer in business.
Old May 29, 2008 | 08:52 PM
Engine: THREEFIDDY!
Re: My L98?
Thanks for the replys guys,
LOL-
Old May 29, 2008 | 09:02 PM
Air_Adam's Avatar
Re: My L98?
What kind of heads are those? They aren't GM castings are they....
Old May 29, 2008 | 10:52 PM
Engine: THREEFIDDY!
Re: My L98?
Stock replacements from RHS. 1.6 ex, 1.94 int. Got them for $30 a piece on the bay new, factory screw up.. had chips in the exhaust seats, sent them to my fathers machine shop.. boom; $60 heads = new
Old May 29, 2008 | 10:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: My L98?
LT1intake i dont beleive is doing that swap anymore. many ppl have tried to contact him and havent heard anything. Its possible to do it yourself or buy one thats already converted
IF you do get one, it will work just fine with TPI wiring harness. Just have to relocate the sensors in the proper position. Only thing that doesnt work is the cold start injector that the 88 has... get rid of that in the prom. i'd convert to the 6E mask from 89 anyway as its alittle better and has no cold start injector
Other option thats alittle more money is the HSR. 650 will have it in the car running
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
