will this work
Old Aug 18, 2008 | 12:40 AM
kccisco's Avatar
Car: 85 transam
Engine: 76 chevy 350 carb
Transmission: t-5 3.23
will this work
well iv searched this forum but cant find anything on this subject. i have an early 80s oldsmoblie 350 in my garage and was wondering would it fit into my 85 trans-am. i know that the computer needs to be adjusted, a new knock censor, and new injectors but i was wondering if it would work or whether i would need to change some other things out.
Old Aug 18, 2008 | 12:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Work" is subjective. You can make most anything that physically fits within the engine compartment "work".
First order of business is to determine if it is a Chevy or Olds engine. Do you know the difference? If Chevy, it's fairly straightforward. If Olds, probably not worth it.
Old Aug 18, 2008 | 07:32 PM
kccisco's Avatar
Car: 85 transam
Re: will this work
well im pretty sure its a olds 350.
but i was wondering was what would be a problem with inserting the olds 350 into my car
Old Aug 18, 2008 | 07:41 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: will this work
BOP (buick olds pontiac) motors are a diff breed. Parts aren't interchangable and you will needa BOP tranny or adapter to use ur trans.
Old Aug 18, 2008 | 07:54 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: will this work
Most BPO owners swap in chevy motors. I guess for the aftermarket parts??
Old Aug 18, 2008 | 11:24 PM
kccisco's Avatar
Car: 85 transam
Re: will this work
well if i was goin to put a 350 into my car what vehicles would be best to pull the engine from? i just want to make sure that the engine will be able to bolt into my car without having to change my motor mounts
Old Aug 18, 2008 | 11:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will this work
Any small block chevy built since 1957 will bolt to your motor mounts.
Old Aug 19, 2008 | 12:47 AM
five7kid's Avatar
1958 model year, actually. '57 only had front engine mounts, the sides of the block were bare.
But, the 350 didn't come out until 1968 ('67 in Camaros only). So, any non-Gen II or III SBC will "work" as a donor.
Old Aug 19, 2008 | 12:05 PM
afida15's Avatar
Re: will this work
Since this is already a pontiac thread already i figure il ask my question in this. I have a opurtunity to get my hands on a 66 326 pontiac temptest motor, im not wanting to put it in any car i was just wanting to know if its worth anything? like is it rare or can i get some money for it?
Old Aug 19, 2008 | 01:49 PM
five7kid's Avatar
#1, this isn't a "Pontiac thread".
#2, it isn't a 3rd gen question.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
