350 4 bolt main
Old Aug 28, 2008 | 07:23 PM
tomorrowshistor's Avatar
Car: 1984 Pontiac Firebird S/E
Transmission: Turbo350
Axle/Gears: 3.08 posi
350 4 bolt main
I am the guy that was going to put the 327 in my 84 Firebird. Turns out the 68 C10 i bought with a supposed 327 is really just a 350. It is a 4 bolt main. the guy i bought it from said it was a 327 bored .030 over. So maybe it is a 350 bored .030 over? Is this a good engine to build from? Right now it has the bore, a hydraulic cam (guy didn't tell me the durations) and a 660 carb. The heads are way to small for this motor, so they will have to be changed. I am working on a budget so does anyone have any ideas on what heads would be good and preferably inexpensive? Should I change the cam cause I have no clue what is in it beside what the dude told me? I have a set of solid lifters and roller tip rockers sitting around that were for a sbc 267 that I was building but stopped when I bought this engine. Will they work on the 350? I am bolting it to a turbo350, what stall should I use? Any suggestions on a starter and headers also? Any other suggestions would be awesome too. Also, should I keep the 660 carb? And the firebird used to have a 305 carbed engine. Thanks in advance.
Old Aug 28, 2008 | 07:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 4 bolt main
"Just" a 350? The 350 is a better engine than a 327.
Have you actually measured the stroke to know that it's a 350 and not a 327?
Old Aug 28, 2008 | 07:42 PM
Re: 350 4 bolt main
Sorry to offend, i was just excited to have a 327 and let down not to have it. Is the 4 bolt main still good since it is not a 2 bolt? i am ran the numbers and that is how I know it is a 350 not a 327. it is a 1975 Chevy truck 350, so I figured it is a 4 bolt.
Old Aug 28, 2008 | 07:46 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: 350 4 bolt main
Yes 4 bolt is more desirable than a 2 bolt motor. I think you will be happier that you have this 350 over the 327 imo
Old Aug 28, 2008 | 08:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 4 bolt main
What numbers did you run?
The 4 bolt is more desired than the 2 bolt, but not necessarily more desirable. There isn't anything streetable you can do with a 4 bolt block that you couldn't do with a 2 bolt.
Old Aug 28, 2008 | 08:30 PM
Re: 350 4 bolt main
The shop where I brought the truck to have the engine removed ran the block casting numbers to find it was from a 1975 chevy truck 350.
Old Aug 28, 2008 | 08:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 4 bolt main
Block casting numbers don't tell you that it's a 350 and not a 327. They both use the same block.
Old Aug 29, 2008 | 03:35 PM
Re: 350 4 bolt main
Then I don't know how the guy at the shop knew. He told me he ran the numbers and it is a 1975 350 truck engine. Sorry for any inconsistencies.
Old Aug 29, 2008 | 04:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 350 4 bolt main
Apeiron is striving to make the point that a 350 can have a 327 crank in it, and becomes a 327. Chances are good that your 1975 truck motor is indeed a 350 - with a 350 crank in it.
But that's the point - chances. If you want to be sure, measure the stroke of the crank.
3.25" = 327 cubes
3.48" = 350 cubes.
660 carb?
what's your budget on this rebuild anyway?
Old Aug 31, 2008 | 06:33 AM
Re: 350 4 bolt main
Thank you much for the help. i will have to get the stroke measured. Sorry too about the typo, I meant 650 cfm carb (that is what is on it now). I didn't really have a budget, but I am trying to stay in a good shopping range. I don't mind spending money on good parts, but then again i do not need top of the line parts. If I spend too much money my girlfriend will kill me because we are saving for a house.
Reddeath210
Oct 6, 2015 08:20 AM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
