Flat tappet cam in roller engine? Will it work?
Old Apr 8, 2009 | 11:48 AM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
I am having some trouble finding info if a hyd flat tappet cam will work in a roller engine. I decided to go with a 1 piece seal (roller cam) block for my 383 build but don't know if I can put my cam in there and have it work. My searches havn't led me to any real answers. Thanks
Old Apr 8, 2009 | 12:12 PM
squeeezer's Avatar
Car: 5 cars
Re: Flat tappet cam in roller engine? Will it work?
its no different than the 88 to 95 truck motors they have flat tappet cams/lifters in a "roller block"
i believe you have to grind a little for a true double roller timing chain though (11,12,1 o clock of cam tunnel ) so it doesnt rub the block
Old Apr 8, 2009 | 12:19 PM
Axle/Gears: 3.23?
Thanks. I guess I should have stated that the block I can get my hands on is from a 96 suburban. Any problems with that?
Old Apr 8, 2009 | 01:26 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
i believe you have to grind a little for a true double roller timing chain though (11,12,1 o clock of cam tunnel ) so it doesnt rub the block[/quote]
You do have to grind on the block to get the double roller to fit....the top oil passage sticks out just a bit.....
Old Apr 8, 2009 | 05:21 PM
squeeezer's Avatar
Car: 5 cars
only difference with that short block and the ones i mentioned is the crank sensor
i believe you can separate the tone ring from the crank and use a regular timing cover
is that all you have of this motor ...the block?????
Old Apr 9, 2009 | 03:04 AM
Axle/Gears: 3.23?
All I would be taking from that engine is the block. That is what the salvage yard said they had available and ready. They have a bunch of two peice seals ready to go. I might just go with that. I was thinking of using my L98 block but wanted to keep the engine complete for selling.
Old Apr 9, 2009 | 07:42 AM
squeeezer's Avatar
Car: 5 cars
keep your flexplate/flywheel then
1 and 2 piece cranks have different bolt patern
Old Apr 9, 2009 | 01:12 PM
Axle/Gears: 3.23?
I was just going to buy a new one since they are relativley inexspensive.
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
