454 engine wear
Old Oct 4, 2009 | 01:35 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
454 engine wear
how to solve the problem
help!
any feedback is good
Old Oct 4, 2009 | 01:38 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: 454 engine wear
Old Oct 4, 2009 | 10:24 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 engine wear
Time for some machine work or a new block.
Looks like a lack of oil problem. The timing set isn't getting any oil. I use a cam gear that has a torrington bearing behind it so the gear itself doesn't ride on the block. Small holes are drilled in the gallery plugs behind the gear to supply it with oil.
Are you using a cam button? If so, is it too tight? When the engine is running, the cam wants to walk out of the block. That wouldn't explain why the cam gear wore into the block unless it was forced in by a too tight cam button.
Old Oct 6, 2009 | 08:02 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: 454 engine wear
looks like there should be a camshaft thrust plate bolted to the block like the 87 up 5.7 liters use and a newer style timing chain too....... the thrust plate keeps the camshaft from walking and also keeps the timing gear from chewing up the block like that
Old Oct 6, 2009 | 08:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks awfully dry there.
I'd guess the front cam bearing wasn't put in properly and starved that part of the engine for oil.
Old Oct 6, 2009 | 11:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 454 engine wear
That's a possibility.
Exactly what block is it?
Flat tappet or roller cam?
From the holes on either side of the cam, it looks like it's supposed to have one of these.
http://paceperformance.com/index.asp...D&ProdID=37092
Old Oct 7, 2009 | 12:17 PM
five7kid's Avatar
I'm not as familiar with roller big blocks, but that looks like a flat tappet cam snout to me.
Even with a cam button, I can't imagine so much force that it wears the block like that.
With a flat tappet cam, two things hold the cam back so the timing gear takes the thrust, the distributor drive gear, and the slight angle on the lobes that spins the lifters. Without oil, the block/timing gear are going to scream against each other.
Old Oct 9, 2009 | 04:21 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: 454 engine wear
block 454 346236.....454.......75-76...2-bolt
Flat tappet
chain used again and again
I want to do roller cam
fill in the gap ? solution : Camshaft, Wear Plate?
http://www.summitracing.com/search/B.../?autoview=SKU
Old Oct 17, 2009 | 08:28 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: 454 engine wear
Old Oct 17, 2009 | 08:35 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: 454 engine wear
solution helps good or bad??
Old Oct 17, 2009 | 02:13 PM
Re: 454 engine wear
thats the ticket. i suggest getting the surface machined flat on the block tho
Old Nov 1, 2009 | 10:45 PM
cj599's Avatar
Car: 1986 sc camaro
Engine: 489 bbc
Re: 454 engine wear
mine did exactly the same thing its a 1988 chevy 7.4 liter truck engine 4 bolt main
why did it do that i lost my mains right after i am going to have it machined flat and use a hardend were washer summit and jegs sell them in thicknesses for what you need
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
