big block question
big block question
is it possible to put a big block engine in my 87 camaro , i have a 3 inch cowl hood , but would i have to do any cutting in the hood to be able to do this if so the i will for get the idea.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Youll probably need to modify your hod, or get a cowl/SS hood. Then, youll have to redo the motor mounts, custom hedders... etc. It CAN be done, but its a big PITA!
-Rob
92' White Trans Am Convertible, 305 TPI, 5 spd. 2:73's, Edelbrock TES, Accell 8.8's, Hypertech Stage II, TPIS Air Foil, Ported Plenum, K&N TB Cone Filter, AFPR, & A Little Bit Of Attitude!
-Best ET: 14.944 @ 93.11
88 Gunmetal GTA Hardtop... Project In The Works!
"GUYS, WE NEED TO FIND A MUSTANG TO RACE... THERES ONE! HOLY SH*T SHES HOT! SHES NOT GONNA GO... NAH... HOLY SH*T SHES GOIN!"
-Rob
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
All the info you need is on my page.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts
www.koolmeister.com
Miles
)www.koolmeister.com
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A low profile intake manifold and/or a drop base air cleaner should help your hood clearance problem. The 3" cowl helps but it will still be a tight fit to keep it under the hood.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
ummmmm....you don't need to modify the motor mounts. I use a 4"cowl, edelbrock performer intake, 14X3 drop base aircleaner. I also have a 2" spacer on TOP of the carb and I'm right against the hood.
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes freshly installed th350 3200 stall, shift kit, reworked valvebody, Megashifter, Biondo linelock ..........YES, it's street driven!
check it out at http://www.bsronline.net
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I was looking into this once when I had my hands on a 454. Anyway, not saying these are the best way to go but Summit does sell a pair of Hooker headers for a BB in a third gen. The part# is HOK-2226. They are the super competition headers and cost $362.95
[This message has been edited by ryn28 (edited November 27, 2001).]
Car: 87 IROC L98
The Hooker Supercomp engine swap headers are the cheapest to get but are not a direct fit. Some modifications are required to get them in the car. You'll also need to either pull the engine out or lift it as high as it will go to get the headers in.
german-motorsport
17
Aug 22, 2001 04:17 AM
