Cam Questions
Old Mar 10, 2010 | 10:12 PM
Iroccer's Avatar
Car: Irocs and only Irocs
Engine: prefer 350s'
Transmission: corvette 700r4s'
Cam Questions
I bought an '86 iroc with a tired 305 tpi. I'm going to build a 350 for it but I'm wondering if i can get a little more cam with out screwing with the computer.I had plan just a stock l98 build but thought a little more grunt would fun.
I realize I need the knock sensor the 350 prom and a few other things I found out about on this site. but how far can I go with the cam with out any hassels. It will probably get headers and a cat back eventually.
You guys are the experts, you bail me out all the time. I know some one has done this before. Any help will be greatly appreciated
Old Mar 11, 2010 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Oh yeah, plenty out there.
First need to know if your 350 is roller lifter or flat tappet.
Old Mar 11, 2010 | 08:07 PM
Iroccer's Avatar
Re: Cam Questions
well I'm going to use a 95 truck block and probably some stock l98 heads unless something comes up.
Old Mar 11, 2010 | 09:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Cam Questions
LO5's were a toss up. You have to visually check if its machined for a roller cam or not. Simply a year wont suffice
Old Mar 12, 2010 | 04:19 PM
Iroccer's Avatar
Re: Cam Questions
well I have a 350 block that came from a 95 chev pick up with vortec heads I probably won' use those heads unless I get a killer deal on a vortec intake base . I can go roller or flat tappet. I need to know what cam to choose with out making the computer go crazy. I just want to make the car a little more snappy than stock because I have a stock Iroc also. I do have a stock chip from an 88 Iroc tpi. Will it plug into my computer? Will that make the cam choices better?
Old Mar 12, 2010 | 04:58 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Cam Questions
A 95 LO5 wont have vortec heads. Centerbolt valvecovers, yes but not factory vortecs. Vortec started in 96 with the CPI
Itd be counter productive to put a tappet cam into a roller block. Find out what you have first
A TPI chip will not work with the TBI PCM. A Fbody TBI chip will also not work with the truck TBI PCM. They are very different. Fbodys TBI ECMs are a derivative of the TPI ECM where trucks started over with a PCM to control the new 4L60E transmission. Even if it did swap over, off the shelf chips are junk. There is no replacement for a proper tune
Old Mar 12, 2010 | 05:38 PM
Iroccer's Avatar
Re: Cam Questions
did I say 95 I meant 96. I want to use the computer in the stock tpi 305 86 iroc. I would like to replace the 305 with a 350. I'm going to use the 96 350 truck block, crank, and rods. I may use vortec heads if I can find an intake base cheap. if not I will go wit circa 86 stock heads.
We're kinda getting off point here. I need to know how much cam the stock '86 computer will take and will an 88 stock chip wor in that computer.
Old Mar 12, 2010 | 05:55 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Cam Questions
It will need a tune and injectors. Youll be beyond maxed on both with the 350 shortblock, 305 heads and TPI on there
L98 Prom/MEMCAL and injectors may get you close, but itll never be perfect
Old Mar 12, 2010 | 06:26 PM
five7kid's Avatar
If I already had Vortec heads, I would do what it took to get a Vortec base before settling for L98 heads.
Old Mar 13, 2010 | 08:33 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam Questions
I agree with five7kid. But if you don't care about power, then sell the Vortec heads, and then you'll have enough $ to finish the project properly.
Old Mar 15, 2010 | 08:28 PM
Iroccer's Avatar
Re: Cam Questions
After all this I think I'm just going to put a stock l98 in place of the 305. I'll get the chip, the injectors the knock sensor, and anything else i need to make it happen
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
