Anyone else using Olds 455 in 3rd gens????
Car: 83 t/a , 89 Formula
Engine: t/a-455 Olds, formula 305
Transmission: soon to be 4 speed, 700r4
Axle/Gears: 2.77, 3.23
I just want to see how many people are using the Olds 455 in their 3rd gens, I thought i was the first but after looking on here ive seen a few more, so post if youve got one in your 3rd gen cars,
anyone using headers??
anyone got a manual trans???
anyone got one under a stock hood??
post some pics of the 455 in your cars!
Im in the process of putting a manual trans with my 455 with headers.
So i would like to see what all else has been done with Olds motors
Re: Anyone else using Olds 455 in 3rd gens????
bump
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you haven't already gotten a response, you probably never will so don't do a TTT/Bump post.
This falls into the category of "If you have to ask, you shouldn't be asking".
An Olds swap will be very similar to a Pontiac swap which you can read about in the sticky at the top of this forum. Same goes for a Buick or Caddy engine. You'll be much better off just doing a BBC swap. It's easier and cheaper.
I cant find the hot rod magazine issue but heres a great link for you
http://www.bangshift.com/forum/index...e;topic=8793.0
http://media.photobucket.com/image/t...ransAm-455.jpg
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Don't get discouraged; just search and search and search....
I did this to my 87 Formula years back, and I did a quickie post about it if you search. Just search my name and you'll find it.
I have also put a Buick 350 under the hood of one. I have not used a 455 Olds, because I had a great running 350. The 455 is a little taller and wider due to the increased deck height to make up for the extra stroke.
Good luck and post lots of pictures!
Engine: 2.8/TBI/TPI
That's a Buick 455.
I like them better, but its not an Olds. It is however, an 11 second car that is mild on the street.
Very nice combo...
Very nice combo...
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
3rd, 455, 480le, 700r4, axle, conversion, engine, gen, olds, oldsmobile, spline, swap, t56, tbi, transmission, transmissions
