350 motor mounts
Old Apr 19, 2010 | 10:56 PM
1985.camaro.350's Avatar
350 motor mounts
I have a 1985 firebird v6. I want to put a 350 from a 1975 blazer, I was wondering what motor mounts would fit both the engine and the stock frame side motor mounts?
Old Apr 19, 2010 | 10:59 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 motor mounts
So you want to bolt your SBC to the V6's frame pads?
Old Apr 19, 2010 | 11:09 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If so, here's what you need:
http://www.summitracing.com/parts/ADD-713111/
Old Apr 19, 2010 | 11:32 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
move the V6 rubber mounts to the V8 holes on the K member (about 1" forward) and the mounts that are on the 350 will probably drop right in.
Old Apr 19, 2010 | 11:36 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's probably what the OP was trying to avoid. To do it, you have to remove the control arms and springs. If the OP was going to do that, then there's no point trying to keep the V6 pads. Plus the bolt pattern is different, so just moving them is out.
Old Apr 20, 2010 | 09:10 AM
Yes I wanted to mount v6 pads if possible, otherwise I will get a set of v8 pads for it. The motor mounts the 350 came with are completely trashed so using them is not an option.
Old Apr 20, 2010 | 11:32 AM
Would the motor mounts from a 305 bolt to the 350?
Old Apr 20, 2010 | 01:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
Moving the chassis side mounts to the V8 position makes the most sense to me.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
st.evel07
Aug 13, 2015 06:15 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
