Need 400hp from my 350
Old May 4, 2010 | 09:53 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
Hey guys what are or is the best combo of parts to get 400hp? It need to be street friendly to this my daily driver. Please help.
Old May 4, 2010 | 10:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need 400hp from my 350
Does it need to be emissions legal? Are you willing to change your axle ratio if necessary? If not, what gearing do you have?
Old May 4, 2010 | 10:12 PM
Axle/Gears: 3.08
Yes, and maybe. I have stock 3.08 in but might go to 3.55
Old May 4, 2010 | 10:18 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
To do it, you're going to need AFR 180 cc heads, with 65cc chambers, flat top pistons, headers, 3" cat-back, Edelbrock intake manifold Extrude-Honed, and a COMP custom 3314/3314-112 cam. With an automatic, a 3.42:1 gear will do, but if you're starting from a TBI 305 / 5-speed car, that T5 has a 0.63:1 fifth, so go 3.73:1.
Old May 4, 2010 | 10:28 PM
Axle/Gears: 3.08
what size of carb. would I need?
Old May 4, 2010 | 10:42 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
To be legal, you must keep your stock carb or EFI. If yours was built with a computer-controlled Q-Jet, it will support 400 HP.
Old May 4, 2010 | 10:49 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
are emissions test in your area visual and sniffer, or just sniffer? if it's visual you must make sure that your heads including intake has an egr port and the heads have a heat crossover IIRC...
Old May 4, 2010 | 10:57 PM
Axle/Gears: 3.08
Visual? I called they check for the factory emision equipment.
Old May 4, 2010 | 11:00 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
that's visual ...
Old May 4, 2010 | 11:09 PM
Axle/Gears: 3.08
Does anyone have a 400hp car?
TX-SleeperC5
Feb 24, 2016 01:34 PM
abray1
Sep 10, 2015 04:53 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
