Double hump heads?
Old Feb 12, 2011 | 05:28 PM
86ta5spd5.0h.o's Avatar
Double hump heads?
I have a set of heads that I think are double humps but I want to know if their are the desireable ones
casting #
3782461
thanks
Old Feb 12, 2011 | 07:25 PM
AmorgetRS's Avatar
Re: Double hump heads?
Back in the day double hump heads were cool... not worth it now days.
Old Feb 12, 2011 | 08:00 PM
9340Ruby's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Most "camel hump" heads came with at least 300 horsepower at least on a 327 block.
Old Feb 12, 2011 | 09:27 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Desirable is a relative term. Those heads used to be all the rage before the aftermarket started making much better heads beginning in the 1980's, and the OEM's started making better heads right from the factory.
Old Feb 12, 2011 | 09:41 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
say someone already had the heads, would they atleast be worth using if machine work and harnded seats have been done?
Old Feb 12, 2011 | 11:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
30+ years ago they were the best option for making power. By today's standards, they're only worth something to people making a period car and want period correct parts on it. The time and money you spend to make these old heads work better, aftermarket iron heads can be purchased for much less and will still out perform the old heads right out of the box. Even newer factory heads such as vortec heads are better.
Old Feb 14, 2011 | 10:23 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Nothing special about the heads. 163cc small valve
Some guys went nuts over the X heads but they were the same size.
Back then engines were a gross rating, different than today. a 1968 300hp and a 2010 300hp are two different animals.
Old Jan 17, 2012 | 06:41 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Are the double humps better than the stock tpi 350 heads(083 heads)???
Old Jan 17, 2012 | 07:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
Old Jan 17, 2012 | 08:04 PM
461 heads can't be installed on these cars without jumping through extra hoops because they lack the bolt holes (and bosses for them) on the ends. You can't install minor details like.... an alternator.
Because of that, and their non-hardened seats which tend not to survive with modern gas, and their lack of the "squish" area that was the hottest technology for 1969, the 461s are the LEAST desirable of all the double-humps.
They are no better than 083. Not as good really, for all the above reasons, and more.
Best left to either "the greater fool" (yes, there's ALWAYS at least ONE out there somewhere), or somebody who wants a "numbers matching" mid 60s setup of some sort.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
TreDeClaw
Aug 14, 2015 06:58 PM
