305 to longblock 350
Old Mar 26, 2011 | 07:12 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
so ive decided to put my 305 to the side and look for A 350 found one for 500!!!
its out of a 70 vett
bored 60 over
down sides it has no crank or valves
but everything else is there!
any help and info on if this will bolt right up or be a problem in
a 92 firebird witth 700r4 hydramatic tranny
any help would be nice!!!!!!!
Old Mar 26, 2011 | 07:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I hope you didn't buy it.
0.060" over is stretching it for a factory 350 block. If the cylinder walls wear or get scratched, you're looking at sleeves or a different block.
'70 heads are nothing to write home about. Even in a Vette.
Vette blocks were the same as truck blocks.
$500 w/o a crank even is collector pricing. Go find a $100 block from an '87-'95 truck, put Vortec heads on it, bolt that in.
Old Mar 26, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: 305 to longblock 350
Are you going to carb this motor?
Bored 60 over means it's been bored as far as it can.
EVERY 350 is out of a vette - that means absolutely NOTHING except that the seller is lying about it's origins - it's probably out of a truck which 90% of all 350's are.
How much is a crank? If a crank is $200, pass - 350's are a dime a dozen complete and running in this neck of the woods - $700 would buy you one that you can hear run before you buy! And why does this one not have a crank? Trust me, even if it is a vette engine, the crank wasn't special enough to take out for something else.
Every SBC is all the same, so don't bother asking if this one or that one will bolt up - they all will, inclusing 283, 302, 305, 307, 327, 350.
Old Mar 26, 2011 | 08:08 PM
dabird07's Avatar
Car: 92 firebird
thanks yall and no i didnt
im browsing around craigs list
and then goin to pull a part for a "junkyard build"
i figure either of them would be the best for it
Old Mar 26, 2011 | 09:52 PM
dabird07's Avatar
Car: 92 firebird
thats my plan now found some parts on summit for it
vortec heads
http://www.summitracing.com/parts/SUM-151124/
and summits top end kit
http://www.summitracing.com/parts/CMB-03-0075/
total is 1200 shipped
plus a 100 dollars for a junkyard motor
think thats going the right route with it?
Old Mar 26, 2011 | 10:11 PM
Car: 1992 RS
Engine: Carbed 350
Skip the kit, get the individual pieces seperately. That air filter won't work, so it's a waste of time/money. Order the intake alone ($187.50), then any Pep Boys has that same carb (1406) on the shelf at $249, then just get gaskets and bolts locally as well.
I don't like kits - you always end up paying for something you can't use.
Old Mar 26, 2011 | 10:28 PM
dabird07's Avatar
Car: 92 firebird
true didnt think of this probbly will end up doing that
the vortec heads are a must though ive been told they the best for ya buck
i already have a cam
leaving a chip out of it for now
want to go tommorow to take a look but weather sucks.. . . .
Old Mar 27, 2011 | 12:48 AM
five7kid's Avatar
One kit I can recommend:
http://sdparts.com/details/scoggin-d...ter/sd8060akit
Old Mar 27, 2011 | 04:29 PM
dabird07's Avatar
Car: 92 firebird
solid kit i need to fo some head research and get the knowledge of em
like cc info valve info etc keep the advice commin!
Old Mar 27, 2011 | 08:15 PM
dabird07's Avatar
Car: 92 firebird
even to tranny??
jw
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
